Golf mk4
Wazzzer
grinding noise from brake pedal
Topic: grinding noise from brake pedal (Read 1491 times)
matttdi
Just got here
19 October 2013, 16:11 »
hi ive got a grinding noise coming from brake pedal it only seems to happen when im going to stop any ideas anyone
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: grinding noise from brake pedal
19 October 2013, 17:36 »
sounds like the ABS is kicking in, could possibly be some dirt in the sensor rings or a shot sensor
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
gm8
19 October 2013, 18:37 »
pads getting down to metal ?
bonny
Here all the time
19 October 2013, 20:59 »
Could be the pads worn down to the metal?
The more you pay The faster you go.....
bonny
Here all the time
19 October 2013, 21:05 »
Quote from: gm8 on 19 October 2013, 18:37
x2
matttdi
Just got here
19 October 2013, 21:33 »
hi no ive checked all pads and they are fine the grinding i can feel is on the brake pedal itself
Rhyso
Global Moderator
Sir Postalot
Reply #6 on:
19 October 2013, 23:24 »
As in feedback?? Does this happen under normal or hard braking?
Fire Up The Quattro
matttdi
Just got here
Reply #7 on:
20 October 2013, 06:36 »
its happened once under really hard braking its not happening every time it seems to happen now when i come to a holt
Rhyso
Global Moderator
Sir Postalot
Reply #8 on:
20 October 2013, 08:55 »
That will be your ABS kicking in
Fire Up The Quattro
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #9 on:
20 October 2013, 10:12 »
something is triggering the ABS prematurely. Like I said get on the ABS rings with a wire brush and make sure nothing is stuck in any of them
Golf mk4
Wazzzer
