Author Topic: Auto Wipers  (Read 7050 times)
Offline Aidey
Auto Wipers
« on: 18 October 2013, 12:59 »
So the pouring rain is with us, im trying to understand how the autowipers work on the gti, do you need to have the lights switched to auto also ???
Sold Mk8 ClubSport
Sold Mk8 Golf R....
Sold Gti DSG 2020 Performance Indium Grey .....
Gti Sold... ClubSport Edition 40 , ... Sold Aug 2018....
Offline DougL
Re: Auto Wipers
« Reply #1 on: 18 October 2013, 13:15 »
No. Wipers on intermittent, lever on the stalk over to the right for maximum sensitivity.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline p3asa
Re: Auto Wipers
« Reply #2 on: 18 October 2013, 13:16 »
Should be much the same as on your Mk6
Are you moving? Have you adjusted the sensitivity switch on the wiper stalk?
Offline Sootchucker
Re: Auto Wipers
« Reply #3 on: 18 October 2013, 13:20 »
As has said above, wiper stalk up one notch from the parked position. The rocker on top adjusts the sensitivity (how much rain it needs to see before it wipes.). Right over to the left is minimum sensitivity and over the right, maximum sensitivity.
I tend to have this right over to the left or one click down from it, and seems to do the job admirably.
Offline Aidey
Re: Auto Wipers
« Reply #4 on: 18 October 2013, 13:30 »
Thanks guys , got it sorted now, i was mixing it up with thinking the sensor would know when it was raining and automatically switch the wipers on :nerd: what a div....
Sold Mk8 ClubSport
Sold Mk8 Golf R....
Offline Sootchucker
Re: Auto Wipers
« Reply #5 on: 18 October 2013, 13:59 »
Ah, but it does it the other way round. If it's raining hard enough, it can automatically switch the lights on  :smiley:
Offline Moro
Re: Auto Wipers
« Reply #6 on: 18 October 2013, 14:41 »
+1
GTi Reflex Silver 5 door DSG: Sat Nav Pro; Dynaudio; Panoramic Roof; ACC; Keyless; Winter Pack; Reversing Camera
Offline dubber36
Re: Auto Wipers
« Reply #7 on: 18 October 2013, 16:19 »
I'm not sure if the 7 is the same as the current Passat, but unlike my 6, if you leave the stalk in the first position all the time, the wipers will come on when it starts raining. In the 6, if the ignition has been turned off, you need to manually start the wipers when it rains to activate the sensor.
Offline Fabio Bignose
Re: Auto Wipers
« Reply #8 on: 18 October 2013, 21:24 »
I think the auto wipers seem to be a bit better than the MK6, not as erratic.
The only problem is the wipers themselves! Useless! Am I the only one experiencing bad smearing, juddering and squelching?!
Took it in today as I felt the screen was contaminated with something ( I had already tried cleaning twice) they gave it a clean with something and this seemed to cure the juddering but the smearing remained. More cleaning and a new set of blades later it's still smearing terribly. Going back on monday  :rolleyes:
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline DougL
Re: Auto Wipers
« Reply #9 on: 18 October 2013, 21:27 »
