Author Topic: Which diesel to use?  (Read 6848 times)
Offline e.l.s
« on: 17 October 2013, 22:10 »
Hi all
Sorry if this has been covered already, I did search but couldn't find the answer
Which diesel would you recommend we use in our new gtd? We've never had a diesel car before and don't know if it's worth paying more for the premium options
Diolch/thank you  :smiley:
red GTD, sunroof. BW 39. Picked up 15.10.13
Offline mcmaddy
Re: Which diesel to use?
« Reply #1 on: 17 October 2013, 22:50 »
use anything but morrisons supermarket diesel.
Offline RikWebb
  • Like tears in rain....
« Reply #2 on: 17 October 2013, 23:11 »
There was a discussion somewhere around here
http://www.golfgtiforum.co.uk/index.php?topic=257669.msg2366103#msg2366103
I find with my MK6 GT Diesel - the 'super' stuff doesn't make a lot of difference, however it does in the wife's Zafira
Hope that helps :)
MK7.5 GTD DSG Isaac Blue 5Dr - 19" Santiago's / Nav Pro / Pano Roof / Keyless / Rear Camera / Mobile Wireless charger
Ordered 22/09/2017 - BW confirmed as 23/10/2017
Previous
MK7 GTD Ordered - May 16th 2013 - Tornado Red, Discover Pro Nav - Promised 16 week delivery - HA!
191 Days = 27 Weeks from order to delivery
Offline Rhyso
« Reply #3 on: 18 October 2013, 03:21 »
This and supermarket fuels in general. Stick to the branded forecourts. The premium diesel isnt really worth the extra on new cars
Offline monkeyhanger
« Reply #4 on: 18 October 2013, 07:48 »
What's wrong with Morrissons? Mine uses Texaco fuel. Never used it myself, but I have used a proper Texaco station without ill effects.
I have been using Shell V-Power for 2 tanks now and it does not live up to expectations for me. I thought the purity would result in fewer regens (which kill mpg) to counteract the fact that it is less dense than regular diesel (shorter hydrocarbon chains I would guess that is) and has an average Cetane number of 52, vs standard Shell which is 56. In short it is less potent and contains less chemical energy per litre. Many people here reporting poor mpg have been using Shell V-power, whereas those using regular Shell (or other diesel) have been reporting far better (around 10% better) mpg.
Historically, in owning 6 previous VW TDIs - they seem to run best on Shell or BP, not so good on Esso.
Offline mullermn
« Reply #5 on: 18 October 2013, 09:08 »
A little while ago there was a good article on here about octane in fuel and why for most of us it's a bit of a myth that paying for higher octane translates to any benefit to the car.
Does a similar article exist for fuel? Why should we avoid the cheap stuff and what's better about the branded forecourts?
Offline mcmaddy
« Reply #6 on: 18 October 2013, 09:48 »
morrisons allegedly use a higher amount of bio additives than other forecourts and vw don't like bio additives.
Offline watson
« Reply #7 on: 18 October 2013, 10:08 »
Morrisons use up to a maximum of 5% ethanol, which is quite normal, and meets EN590 standard.
« Reply #8 on: 18 October 2013, 11:17 »
A higher Cetane value makes the diesel fuel combust more readily when mixed with air and compressed. You are likely to get a more complete burn with a high Cetane value fuel because ignitions starts earlier in the compression cycle. There is always the risk of the molecules at the higher end of the chain length range not completely combusting if ignition starts later in the compression cycle due to a low Cetane rating, so it makes sense to up the Cetane level – to a point. You don’t want the fuel so volatile that it’s like petrol. Cetane rating of 56-58 is considered optimum.
Normal Diesel is a mixture of Hydrocarbons varying from 8 to 21 carbon atoms in length. I suspect that V-power (with a proportion made from gas to liquid process for higher purity) ends up with a lower average hydrocarbon chain length because creation of longer carbon chains than the starting material is precise, hence the lower density compared to regular diesel.
In effect, V-power has less energy per litre to liberate under combustion (as does Petrol – it contains about 12% less chemical energy than Diesel), but the relative purity of the stuff as well as the added lubricity components is supposed to make the most of what is there under combustion and so level the playing field. If my car ends up with more mpg when I switch to normal Shell then I would definitely say that  is not the case.
Difference between branded fuels and supermarket fuels isn’t the fuel itself, but the additive packs – the stuff like the added detergents which help keep your engine clean, some other additives (mainly alkyl nitrates) which lower the temperature and pressure conditions required for combustion (by increasing Cetane number). You tend to get a better set of additives in the branded forecourts.
« Reply #9 on: 18 October 2013, 11:24 »
TDIs don’t like bio additives. They will tolerate no more than 5% addition (EN390 standard?)– on the continent when Bio additions are generally higher than in the UK, you really have to watch out for bio content of diesel when filling up. Biodiesel rots many rubber-like compounds more commonly used on newer diesel engines (which is why you can put it in your ancient Audi 100 diesel, but not newer VAGs).
