Author Topic: Does this mean a new Mechatronics Unit...?  (Read 6303 times)
Offline kingbilly
« on: 17 October 2013, 19:35 »
Help required please.
My GTI is an 07 plate registered in March 2007, currently with 60k miles on the clock.
Just today the DSG gearbox has started to play up.  All seems okay and as expected in Manual mode, however...
In both D and S mode...the car pulls away okay...1st into 2nd...2nd into 3rd...then it won't go into 4th at the expected time/revs.  Revving it hard and then easing off the accelerator tends to move it up a gear...and then the same for 4th to 5th...and 5th to 6th.
Have been unable to see what happens if I were to redline it in 4th or 5th as to whether it would change up properly before the engine blows up.
So, is this a sign of a duff Mechatronics Unit...?  Any idea as to repair cost...?  If I had a Warranty Direct policy...would they cover the full cost...?
I believe that the faulty Units are a VW known batch...anyone know which years these appeared...?
Any help and/or information much appreciated.
Thank you,
Billy
Offline Hurdy
Re: Does this mean a new Mechatronics Unit...?
« Reply #1 on: 17 October 2013, 20:20 »
Before you get paranoid, have you got access to VCDS? Resetting the DSG may put things back to normal.
It doesn't sound like the normal DSG faults that tend to come up, which is jerky transitions through the lower gears resulting in "kangaroo hop".
DSG issues happen throughout the MKV and even MKVI golfs, but had been more prevalent on the 2004-2007 models.
Seat Leon Cupra Black 290 DSG
Offline kingbilly
« Reply #2 on: 17 October 2013, 20:27 »
Thanks Hurdy,
Of course I'm paranoid...have you seen the cost of replacement...seemingly it's about £2k...!!!
No, I don't have access to VCDS...but my local dealer will be able to reset things...if they know what they are doing.  Will pop into them in the morning.
Correct...I don't have any clunking or jerkiness or kangarooing.
Hopefully it's something fairly easy to fix.
Thanks again,
Billy
Offline th3_f15t
« Reply #3 on: 17 October 2013, 21:51 »
I know next to nothing about DSG, but a quick question for you: Have you had the DSG fluid changed according to the Volkswagen schedule?
Moving over to Flickr, sorry for the broken picture links!
Offline kingbilly
« Reply #4 on: 17 October 2013, 22:06 »
Mike,
Yes I have.  Once at 27k miles...and again at 51k miles.  This is actually way ahead of the scheduled every 40k miles.
Thank you,
Billy
Offline th3_f15t
« Reply #5 on: 18 October 2013, 07:46 »
Good stuff. Then I simply wish you luck and a small repair bill! Post on here once you've got it sorted, always handy to know what these things are caused by and how they're fixed.
Offline kingbilly
« Reply #6 on: 24 October 2013, 15:20 »
Progress report.
Car went in to local dealer to have latest software checked and system re-set...£90.  Problem still prevalent...now awaiting feedback from VW Technical.
VW Technical want the car back to the dealer to check...ABS sensors...wheel bearings...and pick up sensors (I think).
They just haven't went for a new Mechatronics Unit...yet...!!!
Offline kingbilly
« Reply #7 on: 30 October 2013, 16:29 »
Problem solved.
Rusty bearing with half missing pick up ring sending duff speed information to Mechatronics Unit hence gearbox not changing up when it should.
Cost £265 plus £90 for software reset.  Could have been a lot more expensive...I suppose.
Offline th3_f15t
« Reply #8 on: 30 October 2013, 18:43 »
Well, sounds like the garage you went to knew what they were doing. Which garage was it?
Offline kingbilly
« Reply #9 on: 30 October 2013, 20:44 »
Mike,
My local dealer is Specialist Cars in Aberdeen.  They have always been good when it comes to problems.
Shame I can't say the same for Volkswagen themselves.
