Author Topic: Silly question about stub axles  (Read 1721 times)
Offline thephatmaster
« on: 16 October 2013, 19:03 »
So my wheel bearing (rear - inner) got seized and spun around on the stub axle making a lot of noise...
I replaced the bearings and inspected the axle (which was a bit discoloured underneath, but smooth) now 1000miles later the wheel bearing is noisy again.
I'm about to replace the stub axle + fit new bearings, but just wondered why it ate another bearing? The bearings don't run on the stub-axle, the race just sits on there!
Anyone got the engineering expertise to answer this?
Offline spikenipple
Re: Silly question about stub axles
« Reply #1 on: 16 October 2013, 19:07 »
No grease in the bearings?
Bearings done up too tight? (easily done)
Races fitted out of square in the discs?
« Reply #2 on: 16 October 2013, 19:14 »
lol - read my mind actually - Bearings were fit into the drums with proper size bearing seating tool - but I earlier today I re-greased and reset bearings as an interim measure - fingers crossed ;)
Also, all this "do the bearing up until you can move the washer with a screwdriver" lark is nonsense because if I can move the washer, there is tons of play in my wheel!
Offline spikenipple
« Reply #3 on: 16 October 2013, 22:50 »
Ideally when fitting new bearings you want to do the nut up as hard as you can with your hand on the socket then nip it up 4-5 degrees whilst spinning the drum/disc.
Offline madmanmart
« Reply #4 on: 17 October 2013, 12:29 »
What make bearings did you use?
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 17 October 2013, 12:43 »
the race hasn't sat flush on the stub and has given some movement, which has over cooked the bearing?
VW BUSH
« Reply #6 on: 17 October 2013, 19:38 »
Spin the wheel while tightening as soon as it slows the wheel back off a tad and check play is no more than 2mm.
Over tight bearings fail quickly.
Never pack the caps with grease and use good high temp lithium castrol/duckhams
As said make sure they are not on the piss.
