Author Topic: Help !!! mk2 gti 8v wont turn over  (Read 5061 times)
Offline jordanmk2gti
« on: 16 October 2013, 14:57 »
Okay im new to the forum so hi, ive got a mk2 golf gti that has been a project to get it on the road was running fine when I got it etc etc gave it a full service for mot and it failed due to having holes in the footwells (pinpricks) so I welded the holes up using a mig welder , disconnected the battery but earthed on the chassis thinking it wouldnt be a problem . Now it wont start fuel pump primes but no ignition, I have changed on it :blue temp sensor,coils, ht leads,spark plugs, distributo cap andd rotor arm,ignition module , new battery. Only thing I thought it could be was ECU or I need a whole new distributor , currently look for a diagnostic port to see if I can get a computer to source the problem but its not under the gearlever seat under the dash near fusebox or behind centre console and as I researched further I heard they dont have them even though I thought it was a 2x2 connector. So can anyone help me get her started up again by giving me advice on whether to find the port or other parts that could be malfunctioning? Thanks in advance (sorry for the essay) jordan
Offline JimR
Re: Help !!! mk2 gti 8v wont turn over
« Reply #1 on: 16 October 2013, 15:23 »
I don't think they do have diagnostic ports? I'm willing to be proven wrong though.
When you say the fuel pump primes, does it keep running or prime for 2 or so seconds then stop? If it runs constantly before you turn the key that is a sign that the ecu has fried. Other than that check all fuses and relays (especially 18 i think it is) are ok and seated properly and all connections to the starter motor are sound, also could it be the ignition switch in the column?
Mk2 GTi.
Offline gazareth
« Reply #2 on: 16 October 2013, 19:46 »
gona need more info. are dash lights working? is starter solenoid clicking? is battery fully charged?
Offline Mr Blue
« Reply #3 on: 16 October 2013, 19:59 »
Hi and welcome to the forum.
Does the engine spin over with the turn of the key?
« Reply #4 on: 17 October 2013, 08:17 »
Fuel pump will keep running as long as your turning the key to start it, and batterys fully charged, there is no sound of ignition at all motor doesnt even turn over no revs registered on th counter when attempting to start
« Reply #5 on: 17 October 2013, 08:19 »
The battery isnt dead, brand new fully charged so no clicking off starter solenoid
Offline weazgti
« Reply #6 on: 17 October 2013, 09:46 »
Bores are probably full of fuel stopping it from turning over
Offline oakgreener
« Reply #7 on: 17 October 2013, 10:04 »
Take the plugs out to see if it turns over. If you have fuel, (or water :sad:) in the bores it wont turn over.
Offline Santiago
« Reply #8 on: 17 October 2013, 18:54 »
Have you checked for a corroded connection of the solenoid trigger wire?  Just unplugging and reconnecting it will probably fix it enough to tell you if this is the fault.  It's a non-waterproof connection in a fairly exposed location.
« Reply #9 on: 20 October 2013, 19:05 »
I have not checked for the solenoid trigger wire, when I take plugs out I can see like a bit of fuel , its not hydraulicly seized is it? How would I go about getting the fuel out of the bores? Bought an ecu of the bay of e to fit to see if that helps.matters should arrive wednesday so will update if it works
