Author Topic: Front strut brace 8v  (Read 2848 times)
Offline V8Rumble
« on: 15 October 2013, 20:00 »
Is there a difference between an 8v and 16v front strut brace, if so what is it. I have one but it sits on top of the expansion bottle and very near the throttle. I have an 8v Golf. :undecided:
Offline Neo Badness
  • Feet are for pedals
Re: Front strut brace 8v
« Reply #1 on: 15 October 2013, 22:52 »
Pic?  just an idle though have you tried turning it 180degrees ?
Offline V8Rumble
« Reply #2 on: 16 October 2013, 11:19 »
Thanks for the reply I will try different positions as I have only tried it as it came from the seller on Ebay. If not I will try and sort a pic.
Offline V8Rumble
« Reply #3 on: 17 October 2013, 22:12 »
I have tried rotating the brace but one cure creates another problem, here is a couple of pics sorry about the quality they are off my phone
« Last Edit: 18 October 2013, 20:22 by Thom89 »
Offline Gambit
« Reply #4 on: 18 October 2013, 10:14 »
see if you rotate the bar 180degree, will it clear the throttle body - but then foul on the coolant bottle?
id a similar issue on my 16v where it was tight up against the coolant bottle but i just dropped the coolant bottle an inch by making a modified bracket. also, mine is the earlier type coolant bottle whereas yours is later type
Offline V8Rumble
« Reply #5 on: 18 October 2013, 10:25 »
I did try rotating it but to stop it fouling anything I would have to lift it up but then there is bonnet clearance. I was going to move the coolant bottle around the strut tower rather than lower it just to be sure I kept correct height.
Looks like I have some work to do I foolishly thought it was a bolt on job lol and didn't want to start messing about if it was for another car, ho hum :whistle:
Offline Gambit
« Reply #6 on: 18 October 2013, 14:14 »
The coolant bottle just needs to be higher than the inlet on the side of the head, so you can drop it an inch no problem
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #7 on: 18 October 2013, 20:25 »
Note to OP,
Use the IMG code on Photobucket for a full size picture :wink: :cool:
Thom
Offline V8Rumble
« Reply #8 on: 18 October 2013, 20:32 »
Thanks for the replies and advice. How do I do the photoshop thingy?
