Author Topic: mk2 16v wont fire  (Read 2500 times)
Offline Benrevs
mk2 16v wont fire
« on: 15 October 2013, 15:01 »
I have fuel and i have spark. I have fitted an ecu relay in number 3 as it was empty (is it meant to have one)? The car was not running when i bought it but the engine has been rebuilt.   what's next, timing?!
Offline Benrevs
Re: mk2 16v wont fire
« Reply #1 on: 15 October 2013, 15:01 »
Hazards are on the steering column, so ce2?
Offline Gambit
« Reply #2 on: 15 October 2013, 17:43 »
if there is fuel n spark then timing. and then check for compression too if rebuilt & a non runner
no need for relay 3
http://www.dubscene.net/forum/topic/3548-mk2-golf-relays-bulbs/
Offline Benrevs
« Reply #3 on: 15 October 2013, 18:33 »
Ok, I wasn't sure so I stuck one in there anyway.   I have only ever owned Digi's so this is fairly new to me.
  I will check the timing next then, anything in particular I should know about their set up? Cheers
Offline Gambit
« Reply #4 on: 15 October 2013, 20:07 »
Nah nothing special, just check timing marks all align.
Does the isv buzz (if you feel it) when ignition is on? Does it even attempt to fire? Or is it just cranking?
Check rotor arm, and leads on dizzy cap are correct order also.
Offline Benrevs
« Reply #5 on: 15 October 2013, 21:34 »
Yea isv is fine, i swapped the cap and arm for another.. No change.  Gunna check the hall sender tomorrow and change the leads i think.
Offline Benrevs
« Reply #6 on: 15 October 2013, 21:35 »
Not even a mutter while cranking.
