Author Topic: Radio antenna cable.  (Read 3386 times)
Offline Butlam
« on: 14 October 2013, 13:58 »
Hi I have recently lost radio signal in my mk3 and after poking around with a multi meter have deducted that there is a break in the small section of aerial cable that runs from the back of the stereo to a join behind the glove box.
Now I don't recognise this connection and therefore have no idea what to look for. I have been to Halfords who said they do not stock them, I went to an independent car audio shop who also didn't have any, I even went to a dealer and they said the part is obsolete.
I have now contacted 4 separate people breaking mk3's on eBay only to be ignored by all 4.
Can someone please help me by telling me if it is a standard cable I can get online or be able to sell me one. I really don't wanna have to pull down my headlining and change the whole thing.
Thanks.
Offline bigberty101
Re: Radio antenna cable.
« Reply #1 on: 14 October 2013, 14:50 »
I used standard Ariel cable from a house hold, just as long as you join the inside thin cables together, solder and insulate it really well so you don't get interference. also you need to join the outer cable metal platted wrap  together, solder and again, well insulate it you will be fine bud
Offline mad4vws
« Reply #2 on: 14 October 2013, 22:22 »
the aeril wire comes in 2 sections have 1 if u need ?..
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 15 October 2013, 09:52 »
If i remember rightly it joins behind the glove box? (I believe it's a bit tucked away behind some sound proof/spongy stuff) and simply pushed together
« Reply #4 on: 15 October 2013, 13:07 »
That sounds about right from memory mine had a join behind the glovebox which was wrapped in foam.
