Author Topic: Alarm!!  (Read 1826 times)
Offline Luke1981
Alarm!!
« on: 14 October 2013, 11:26 »
My bloody car alarm every now and again decides to go off after locking the car with the central locking remote. All my doors are locked and the central locking seems fine.
What could be causing this? The alarm is the standard fiited one from VW.
Thanks
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Alarm!!
« Reply #1 on: 14 October 2013, 11:34 »
Mine does this if I press the lock button a bit to much in my OCD way of making sure its locked. I just make sure I don't press it to much now and it hasn't gone off for ages now.
Doubt that helps :laugh:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Nino
Re: Alarm!!
« Reply #2 on: 14 October 2013, 12:42 »
Its more than likely your interior sensors going... To test this on the piler behind your drivers seat right down the bottom there is a button, press that button while the ignition is on and it will deactivate the interior sensors.
Current - MK6 GTi Edition 35 - Candy White - 3 door
jamie16v
Re: Alarm!!
« Reply #3 on: 14 October 2013, 12:49 »
mine kept going off everytime a truck or a bus went past, so I ripped it out..  :evil: :smug:
Offline mcgee9t2
Re: Alarm!!
« Reply #4 on: 14 October 2013, 12:57 »
mine kept going off cause of a dodgey door module, kept thinking the door had been opened.
Offline Luke1981
Re: Alarm!!
« Reply #5 on: 14 October 2013, 13:18 »
Thanks' I'll give this a go. Does it deactivate the sensors permanently or do I have to press the button every time?
Offline Nino
Re: Alarm!!
« Reply #6 on: 14 October 2013, 18:00 »
Not 100% certain but I think it perm disables them until you press the button again.
Offline mcgee9t2
Re: Alarm!!
« Reply #7 on: 14 October 2013, 18:45 »
Nope. Press it disables the sensors inside the car for one time only once the car is inlocked it goes back to normal.
