Author Topic: Rough idle???  (Read 1695 times)
Hali
Rough idle???
« on: 13 October 2013, 17:24 »
When ever I floor it my car will run rough for a while and when sitting in traffic it starts idling very rough anyone know what it could be? It's aum 1.8t with forge tip and milltek cat back
Offline barrym381
Re: Rough idle???
« Reply #1 on: 13 October 2013, 17:38 »
try cleaning the throttle body an check with vw if your car is due coil packs under the recall  :smiley:
Hali
Re: Rough idle???
« Reply #2 on: 13 October 2013, 18:26 »
I've tried VW for recall no luck  :sad: I think I've seen Throttle body cleaner in halfords, it sometimes hesitates and then pulls really fast does that sound like the throttle body?
Hali
Re: Rough idle???
« Reply #3 on: 13 October 2013, 18:28 »
Gonna give it the full works soon coil packs plugs oil clean the throttle body, then a trip down to r-tech I think  :grin:
Offline dom
  • Back in a Mk4
Re: Rough idle???
« Reply #4 on: 13 October 2013, 18:47 »
Could also be a split breather pipe
Offline brewey
Re: Rough idle???
« Reply #5 on: 13 October 2013, 19:13 »
What diverter valve are you running? Sound like when my OEM one split.
2000 1.8T ARZ - OEM+
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Rough idle???
« Reply #6 on: 13 October 2013, 19:52 »
lambda can also cause this. You need a VAG COM scan to make sure
Hali
Re: Rough idle???
« Reply #7 on: 13 October 2013, 20:30 »
Stock dv, when I had the forge tip done they found split pipes under the manifold and changed it
Offline brewey
Re: Rough idle???
« Reply #8 on: 13 October 2013, 21:35 »
My guess is split diaphragm in the DV. Either get a forge 007p or 008 or the new revision OEM 710 vag DV
Hali
Re: Rough idle???
« Reply #9 on: 13 October 2013, 21:37 »
Was just reading another post about it running rich if the mafs been unplugged and that the cat can get clogged up?
