Author Topic: Where you get yours  (Read 2726 times)
Offline johnomk4
Where you get yours
« on: 12 October 2013, 21:07 »
Where is the best place to get a ko3s tip??
Offline Chris#101
Re: Where you get yours
« Reply #1 on: 12 October 2013, 21:14 »
R-tech  :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline johnomk4
« Reply #2 on: 12 October 2013, 21:17 »
Thanks mate how much?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 12 October 2013, 21:30 »
£125, no stock at the moment though
Offline Nino
« Reply #4 on: 12 October 2013, 21:53 »
I got mine from creation motorsport for £79.99
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #5 on: 14 October 2013, 09:03 »
Check the forge outlet on eBay I got an ex-display one for 75quid, basically brand new except the forge logo was worn slightly but who's looking?! Bargain :cool:
http://stores.ebay.co.uk/Forge-Motorsport
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline johnomk4
« Reply #6 on: 14 October 2013, 10:39 »
Will that defenatly fit the ko3s?
Offline Perryd84
« Reply #7 on: 14 October 2013, 11:02 »
There's a few different TIP listings, if you go into them they have the engine codes listed in the item description so which ever engines have the K03s then I guess you're good.
Mine has an extra port which came plugged and isn't used on my K03 so maybe this is used on the K03s I'm not to sure :huh:
Offline Nino
« Reply #8 on: 14 October 2013, 18:01 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 14 October 2013, 21:23 »
Depends on your engine code. AGU doesn't need as many ports as any of the others and also has the DV/hockey puck swapped round. A TIP designed for the AGU will fit the K03s and K03 though
