Author Topic: Bottom arm bolt guide  (Read 2017 times)
Offline Mcwill
« on: 12 October 2013, 20:40 »
Hi guys, replaced both bottom arms on golf over last couple of days and on removing the first one I dint realise there is a bolt guide thing? So bent it while removing the arm oops :whistle: so my question is do I need it and if so what is it called and where can I get one.
Thanks folks
Offline weazgti
Re:
« Reply #1 on: 13 October 2013, 00:16 »
It's a sleeve and will cost you around £1.50 from vw. I'd make sure it goes right in aswell with the arm straight because I ve had issues with the bolt going tight but it stil knocking cos the sleeve didn't go right in
Offline Mcwill
Re: Bottom arm bolt guide
« Reply #2 on: 13 October 2013, 10:08 »
Thanks mate got one on order.
Offline Gambit
« Reply #3 on: 15 October 2013, 11:52 »
Or just replace the rear bushes with TT/R32 items and you wont need the sleeve. they are a far superior bush to that of the mk2 item
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 16 October 2013, 11:21 »
This - all day long.  Delivers significantly improved front end pointiness.
