Author Topic: few pic rehab. my mk3. also have an issue i need advice on  (Read 4852 times)
Offline stainesy
ok this is my mk3 gti AKA rehab.
just thought id add a few pics to see what everybodies thoughts are on him lol
i have developed an issue. got a feeling it may be coil but want other opinions aswell.
few months ago i put on brand new plugs. leads
oil and filters.
have developed an intermiten problem now. whenon idle car is fine as soon as i rev from idle it seems to suck in air and almost die then the revs pic up fine. its almost like its not running on all pistons till it gets to like 3000 revs then its fine.
then its totaly fine drive perfect. but ever now and then it will be a b!tch to start. sometimes if im as a set of lights waiting tick over fine i go to pull away then it splutters and coughs then with more revs its fine again.
any ideas?
here are a few pics  :laugh:
Offline tweed
Re: few pic rehab. my mk3. also have an issue i need advice on
« Reply #1 on: 12 October 2013, 10:50 »
Plugs do this. Runs sh!t then work about 3000/4000rpm.
So since you've replaced them it will be coil.
Offline andy_k
« Reply #2 on: 12 October 2013, 14:51 »
I had a horrible flat spot at about 2000rpm -
Plugs, leads, distributor cap, rotor arm made a little but no real difference
Swapped the MAF out for a known good one (just to eliminate that) - no effect
One can of injector cleaner into a tank full of fuel and it was gone :)
Offline stainesy
« Reply #3 on: 12 October 2013, 15:16 »
ah sweet i will try that. i have just cleaned the distributor and seems to have helped abit.
Offline andy_k
« Reply #4 on: 12 October 2013, 15:24 »
it's always worth a try - cheap and doesn't involve getting your hands dirty :)
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 12 October 2013, 15:57 »
I would also recommend a new temp sensor, they control fuelling and can make the car run rich/lean at lower rpm (it should be part of a good service t.b.h along with the throttle body clean up)
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 13 October 2013, 23:10 »
Check the throttle flap aint filfhy  :grin:
If it is then get some carb cleaner spray on it with a tooth brush
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Shizzle
« Reply #7 on: 14 October 2013, 07:43 »
Hi are you from dunstable I have seen this in morrison s in houghton regis alot?
MK3 Golf GTI 2.0 16v 3Door Storm Grey
  • Back in a Mk3...
« Reply #8 on: 14 October 2013, 09:19 »
t.b.h you wouldn't miss it!!  :grin:
Offline Shizzle
« Reply #9 on: 14 October 2013, 09:24 »
Yeh i never do i see it a lot round here i was going to buy it when it was advertized on Gumtree but a 3door 16v came along for 500 mot's and taxed :).
