Author Topic: Alarm help  (Read 2362 times)
Offline Keebie
Alarm help
« on: 10 October 2013, 21:23 »
Just got a mk3 golf 8v gti
Been looking for the alarm brain,I'm not sure it as a alarm on it,I have no key fob just a key with a button which light a light on the key, I found a bunch of wires which I believe to be for the alarm, 3 wires have been cut 2 green wires and 1 brown/white,a power wire which as no fuse in it,these wires are just above the fuse box, the wire loom runs to the passenger side and goes up behind the heater matrix,the alarm as 2 sensors 1 at each side of the windowscreen,I found something that sits round the ignition barrel,
I would like to get the alarm to work any help would be great.
Many thanks
Offline Screech16v
  • MK3 20vt AGU
Re: Alarm help
« Reply #1 on: 10 October 2013, 22:11 »
Tbh your probably best off removing the old alarm as its probably been disabled due to it being faulty and fitting a new one like this ,has flick keys and will give you remote central locking
http://www.rclick.co.uk/product_info.php?cPath=49&products_id=1138
Offline Keebie
Re: Alarm help
« Reply #2 on: 11 October 2013, 08:27 »
Could I cut all the wires from the old alarm ?
the wires from the alarm are
RED              goes to the fuse box (no fuse in it )
BLACK               earth
GREEN x 2          both been cut
YELLOW/BLACK   joins a red/yellow wire   ( ? -footwell )
BROWN/WHITE    cut
ORANGE               joins a green wire  (?-footwell )
RED + BLACK      led
PURPLE               joins a grey wire (no idea where it goes )
BLUE/BLACK        joins a brown/white
BLUE               goes to footwell
BLACK/RED          joins white box back of fuse box
YELLOW                joins yellow box back of fuse box
I hope this helps,
Thanks for your help.
« Last Edit: 11 October 2013, 10:17 by Keebie »
Offline Screech16v
  • MK3 20vt AGU
Re: Alarm help
« Reply #3 on: 11 October 2013, 19:02 »
I wouldn't cut any wires if every thing on the car works you could end up disabling your car,just remove the brain to the alarm,sensors and siren and leave the wires if your not sure or get an auto sparky to sort it.
Offline Keebie
Re: Alarm help
« Reply #4 on: 13 October 2013, 10:08 »
Any idea where the brain for the alarm is ?
Offline TEST100
Re: Alarm help
« Reply #5 on: 13 October 2013, 12:08 »
My original scorpion alarm thats disabled is positioned behind the glove box.but like screech says if it works dnt cut anything unless u know what ur doing :)
Offline Screech16v
  • MK3 20vt AGU
Re: Alarm help
« Reply #6 on: 13 October 2013, 15:29 »
Mine was behind the drivers side kick panel below the bonnet release :smiley:
