Author Topic: some amplifier advice  (Read 11930 times)
Offline navmk4gti
Re: some amplifier advice
« Reply #10 on: 10 October 2013, 20:59 »
Yes i know hence why im going to amp them all up. Im not getting a sub as dont want that much crazy bass.
Ill wire the 6x9 and front speakers to a 4 channel amp and leave the rear speakers as they are.
Offline dragonfly
« Reply #11 on: 10 October 2013, 21:04 »
It's a good start and will sound better than what you have.  Take your time wiring it up and don't botch anything otherwise you can cause shorts and further damage.
Offline navmk4gti
« Reply #12 on: 10 October 2013, 21:16 »
Yup will do thanks for the advice  :smiley:
Offline Len
« Reply #13 on: 14 October 2013, 12:42 »
6x9's in rear shelf are rubbish mate! Ditch em and just amp the door speakers.
www.sas.org.uk
www.the-ace.org.uk
Offline navmk4gti
« Reply #14 on: 22 October 2013, 19:34 »
Yup i am now going do ditch the 6x9s now after little research :grin:
I av got small 8" subwoofer sony xplod 200w which i will be making a stealth box for.
I have a 4 channel amplifier and just had a quick question. Should the wiring be a set of speakers on chanel 1 and 2. And the subwoofer bridged on 3 and 4?? :undecided:
Also which channel have the hpf lpf stuff switched on for?
Offline dragonfly
« Reply #15 on: 22 October 2013, 19:59 »
Assuming the amp is bridgeable then yes use channels 1 and 2 for the front speakers and bridge 3 and 4 for the sub.  Put the HPF/LPF to LPF or off.
Offline navmk4gti
« Reply #16 on: 22 October 2013, 20:07 »
Yup its bridgable. Do i not set lpf for the subwoofer channels. The speaker channels wi be on off. Never wired up subwoofer before :grin: i heard channels for sub needs to be hpf or lpf one of them
Offline sharki786
  • GOT BOOST??
« Reply #17 on: 23 October 2013, 07:12 »
What is hpf & lpf all about?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dragonfly
« Reply #18 on: 23 October 2013, 08:52 »
Yes as above set your HPF/LPF to 'LFP'. Don't forget to set your crossovers.
Offline navmk4gti
« Reply #19 on: 23 October 2013, 09:06 »
LPF stands for low pass filter, which i think is treble cut filter. HPF stands for high pass filter which is a bass cut filter.
So ill set the sub channels to lpf to cut out the treble to it. :smiley:
