Author Topic: Clutch cable snapped?  (Read 2972 times)
Offline lighters
« on: 09 October 2013, 22:32 »
Golf gti mk4 2000 w reg - AGU
I was driving along in 1st gear pulling away from the traffic lights and I just heard a snap like sound and my clutch just pressed in very hard and bolted itself to the floor. My car just wouldnt move. The clutch is still stuck to the floor and I managed to pull over within 50yards and park up. I didnt put it back into another gear I just rolled down the hill in neutral.
I am going to call the RAC tomorrow, anychance they can fix it at roadside?
What is it likely to be? clutch cable?
How much are we talking?
Is it a hydrolic clutch or normal?
I did get a new clutch when I bought the car in May 2013 if that makes a difference
Offline barrym381
Re: Clutch cable snapped?
« Reply #1 on: 09 October 2013, 22:35 »
sounds like your pedal has snapped  :sad:
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #2 on: 10 October 2013, 08:32 »
+1 What Barry said. Snapped pedal
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline mcgee9t2
« Reply #3 on: 10 October 2013, 09:56 »
Be the clip on the end of the pedal.
Don't know why vw decided to make that clip plastic.
Have a look see if there's any plastic in te footwell
And pray that it didn't bend the master cylinder like it did mine.
Offline lighters
« Reply #4 on: 10 October 2013, 20:16 »
Aww that sucks, took it into the garage today and still dont know what was wrong with it.
If it is the clutch somehow and I would be getting it replaced under warranty. I am considering remapping and upgrading the car so which clutch/other options should I be considering? And can someone give a direct link or company to consider as I will need to purchase shortly. Will also be considering a milltek exhaust and running a carbonio airfilter currently.
Offline gm8
« Reply #5 on: 10 October 2013, 20:21 »
Its not the clip , its the weak metal welds were the clip is housed.
my push rod bent a bit too , but still works fine 8 months on :)
http://uk-mkivs.net/forums/t/18012.aspx?PageIndex=2
Offline lighters
« Reply #6 on: 11 October 2013, 12:31 »
Garage said it was the clutch pedal box.  That's all I know at the moment I have no idea how much that will cost.
Delta-Force
« Reply #7 on: 11 October 2013, 14:54 »
if your good with a spanner remove the pedal find the bit that pinged off and get it welded back on this will be stronger than the oem pedal and if you know someone who welds wont cost you anything to fix  :cool:
Offline lighters
« Reply #8 on: 11 October 2013, 16:57 »
Cheers. Sounds like an easy n cheap fix then
Offline lighters
« Reply #9 on: 12 October 2013, 12:18 »
Wow, the garage I got it towed to said it would cost me £200-300 for the clutch pedal box including labor.
Called http://vee-dubs.co.uk/ and they quoted £30 for the clutch pedal box or £60 including labor!
Hopefully it gets sorted! said it can be done today! so v happy if it works out
