Author Topic: Is it worth cleaning maf sensor  (Read 1900 times)
Offline james2
  • No scammers please.
« on: 09 October 2013, 20:02 »
Looking at the amount of crap that came out of his (at 5.00), is it worth doing or leave it as it could damage it. I have electrical contact cleaner and would like to clean mines as it gone over 100,000 miles.
http://www.youtube.com/watch?v=dwm3sYYdA6g
« Last Edit: 09 October 2013, 20:05 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline GTi_James
Re: Is it worth cleaning maf sensor
« Reply #1 on: 09 October 2013, 20:52 »
Clean it, worst case you have to replace anyway
« Reply #2 on: 10 October 2013, 10:55 »
If it is working all ok, I would leave it alone tbh.
Offline james2
« Reply #3 on: 10 October 2013, 20:57 »
it ticks over a bit lumpy and fells down on power, i just though after 100,000 miles will it be dirty as im using a induction kit with out oil on the filter for a year
Offline GTi_James
« Reply #4 on: 12 October 2013, 23:42 »
Give it a squirt with some electric contact cleaner, mines running fine, didn't remove the housing just squirted into maf either side and cleared it up, cars pulling beautifully and idling solid
Offline james2
« Reply #5 on: 13 October 2013, 19:42 »
Thanks will give it a clean.  :wink:
Offline dom
  • Back in a Mk4
« Reply #6 on: 13 October 2013, 19:52 »
Unless you think there is anything wrong with it then I'd leave it alone. If it ain't broken, don't fix it springs to mind. That and they can be very sensitive.
Offline GTi_James
« Reply #7 on: 13 October 2013, 20:51 »
And this
