Author Topic: Mk2 Golf central locking  (Read 2046 times)
Offline richie2480
« on: 09 October 2013, 13:18 »
Hi all, got a problem that has developed. My central locking is working intermittently. Some days it would work fine and then another (like today) it won't. I can open doors with key but not central locking. If I operate it and its not working I can't hear the pump working, and vise versa when it is working I can hear the pump. Is this a pump fault or electrical?
Offline dragonfly
Re: Mk2 Golf central locking
« Reply #1 on: 09 October 2013, 14:50 »
Sounds like the pump.
« Last Edit: 09 October 2013, 15:16 by dragonfly »
Offline Mr Blue
« Reply #2 on: 09 October 2013, 19:58 »
A first guess is a faulty main drivers door actuator or a break in the wiring at the door joint.
Take the door card off and get to the actuator wiring.
Bridge the red to red/yellow - check if pump works.
Bridge the red to red/white - check if pump works.
If the pump works it's the actuator.
Offline richie2480
« Reply #3 on: 12 October 2013, 17:04 »
I did buy an actuator from Maplins a while back but when I went to install it the wiring is different. Is there somewhere I can purchase a VW one?
