Author Topic: Power flexing Front end Golf MK3 GTI what to Power Flex  (Read 4167 times)
Offline tweed
Re: Power flexing Front end Golf MK3 GTI what to Power Flex
« Reply #10 on: 08 October 2013, 17:25 »
Hi i get 30% of power flex and VAT free what is it worth doing on front end if im going to drop my car.
i know this will put a lot of strain on lower wishbones so i have baught all the bushes for them what can some 1 recommend for me????
can you get me full kit for a bmw e36 m3 3.2 evo? Front, rear, everything lol
Offline Bellend
« Reply #11 on: 08 October 2013, 17:58 »
I Powerflexed the rear beam and front wishbone bushes. Didn't do top mounts as I like my teeth. With a decent 800 quid at the time FK coilover kit it handled really well. On super super rough surfaces the car would skitter a tiny bit more than rubber but the handling well made up for it.
Where all my moneys went.
Offline Shizzle
« Reply #12 on: 08 October 2013, 19:58 »
I cpuld mayb get a price for you just my boss get funny sometimes when ordering fpr other people if you go on powerflex website and pm all the part numbers you need.
And yeh im deffo doing wishbones and anti rollbar il leave top mounts im putting stretch tyres on so im not expecting super handling on 185/45/15 lol.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline Ess_Three
« Reply #13 on: 08 October 2013, 22:23 »
Change the rear wishbone arm bush to TT/R32 ones. better than powerlfex.
Better how?
..but gaining motorcycles.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #14 on: 09 October 2013, 19:10 »
Been OEM  rubber I'm guessing they have slightly more compliance?
Offline boneybradley
  • Back in a Mk3...
« Reply #15 on: 09 October 2013, 19:38 »
the r32/tt bush is still rubber so still has a bit of flex but the bushes are more solid than mk3 bushes so they tighten it up without going too hard
Offline Ess_Three
« Reply #16 on: 09 October 2013, 20:40 »
So does more compliance make it better?
Or do people fit poly bushes to tighten things up?
I've never found fully poly bushed lower arms to be harsh...and besides, half the people complaining are running £200 coilovers with the car dumped in the weeds. Erm...kettle calling pan?
  • Back in a Mk3...
« Reply #17 on: 09 October 2013, 20:57 »
but with the r32 bushes you get an in-between of std flexi bushes and stiffer poly bushes. Which is what I want
I have a pair to fit to mine when I re-do the suspension (I'm also going for a quality susp kit if funds allow!) and hopefully my car will handle loads better but also retain good comfort levels? (I hope as r32 bushes are more expensive than powerflex!)
VW BUSH
« Reply #18 on: 10 October 2013, 12:49 »
iirc the std type bush is a tight fit on the OD and is pinched on the metal insert that runs through the middle giving a torsional load, where the aftermarket types tend to be more of a bush, almost free floating.
This is why mine creaked as they were turning when the rear arm moved...
Lots of makes so this may be different by the brand.
One thing to remember is that injection moulded PU bushes set really badly and fatigue quite quickly due to the material properties required for volume moulding and ease of manufacture. For want of a better description cast bushes are best as the material is a different grade and will survive longer with a lot less setting and fatigue. They are harder to make so cost twice as much as most internet brands :smiley:
Offline Shizzle
« Reply #19 on: 10 October 2013, 12:54 »
yes the smaller bush of the 2 is very tight and manage to crush the wishbone now in the bin i will need to melt that bush out the larger pushed out easy with the press.
