Golf mk4
Wazzzer
Map sensor pipe
Topic: Map sensor pipe (Read 980 times)
mrsaunders
Map sensor pipe
08 October 2013, 09:49 »
Does anyone know where I can find pre made intercooler pipe with the map sensor cut out already there
Dalo Harkin
Re: Map sensor pipe
08 October 2013, 13:13 »
Forge do them
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Re: Map sensor pipe
08 October 2013, 15:56 »
as above unless you make one up buying the bits separate but then its more expensive... £45 ish iirc from forge
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
Golf mk4
Wazzzer
Map sensor pipe
