Author Topic: Where can i buy uprated Rear Top Mounts for my Mk4 1.8t  (Read 1582 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Hi there, can anyone recommend where to buy a pair of uprated rear top mounts  :smiley:
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline xtetx
Re: Where can i buy uprated Rear Top Mounts for my Mk4 1.8t
« Reply #1 on: 08 October 2013, 08:45 »
Matty, do you mean the spring isolator on the back?
http://www.psituning.com/product.php?xProd=21384
« Reply #2 on: 08 October 2013, 12:48 »
Hi Dan, its not those dude, its the part that fits to the top of the rear shock and then bolts to the underneath of the arch
Offline dom
  • Back in a Mk4
« Reply #3 on: 08 October 2013, 13:05 »
May I ask why you want uprated ones? They're metal with a rubber insert so I can't see there being much to gain by upgrading them.
« Reply #4 on: 08 October 2013, 22:23 »
Hi Dom, it was just to see if anything was out there to replace the standard ones, im in the middle of re newing every nut and bolt on the car etc, putting new coilovers on so was gona uprate the top mounts if possible
I've seen some uprated FEBI ones on eBay and there only £30 not bad for 30 dibbs
