Author Topic: VAG code 00670  (Read 2353 times)
Offline Jasikasisback
VAG code 00670
« on: 07 October 2013, 22:37 »
Fault code came up tonight...so I guess the throttle body position sensor is the problem.
I have read that it can be reset by simply unplugging the battery for 10-15 minutes and then sticking the key in and turning it to the on position without starting it for a few minutes and then driving it around for 15 minutes or so....
Any advice would be appreciated
Re: VAG code 00670
« Reply #1 on: 07 October 2013, 22:40 »
Found the post on here thanks....(local search didn't work but google found it for me...)
just wondering if I have to do anything else as mine is an automatic..
« Last Edit: 07 October 2013, 22:42 by Jasikasisback »
Offline bigberty101
Re: VAG code 00670
« Reply #2 on: 08 October 2013, 10:55 »
what engine are you running? for instance the abf's have the wiring to the sensor going over the exhaust and that melts them / makes them brittle and the snap
Re: VAG code 00670
« Reply #3 on: 08 October 2013, 13:08 »
I have the AAM engine 1.8 CL...I don't really have an idea of where the sensor is located..would love a picture or good explanation so I can take a look at it.
Re: VAG code 00670
« Reply #4 on: 08 October 2013, 20:56 »
code gone but still runs poorly..:)
