Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121028 times)
Offline DougL
Re: MK7 and VCDS (VAG-COM) thread
« Reply #90 on: 17 October 2013, 18:34 »
The micro-can definitely works on my car, as I have just enabled the alarm chirp. Thanks Norbreck!
The other thing I would like to do is change my servicing schedule from Flexible to Time and Distance. Unfortunately I have no idea how to do this, but I know it involves instrument cluster adaptation and it all seems very complicated. Any chance of some help please?
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline mcmaddy
« Reply #91 on: 17 October 2013, 18:58 »
take it back to the dealer and get them to do it as they should have asked what service schedule to use before delivery.
Offline GrahamFR
« Reply #92 on: 17 October 2013, 19:02 »
So do they match the headlights?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline GrahamFR
« Reply #93 on: 17 October 2013, 19:06 »
Sorry meant to quote like reply#79
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline DougL
« Reply #94 on: 17 October 2013, 19:09 »
Indeed they should have done and I should have checked. Taking it in is a pain and I will ask them to do if it has to go in for any other reasons. However, seeing as I have the means to reset it, then I think I should go ahead and do it!
EDIT
Just reduced the maximum time to service from 730 day to 365 and the maximum mileage from 32200km to 16100. That should sort it. Three options on the ESI reset adaptation channel. Was set to no warning, other options are reset and warning active. Which one to choose?
« Last Edit: 17 October 2013, 20:12 by DougL »
Offline monkeyhanger
« Reply #95 on: 18 October 2013, 07:33 »
For revenue reasons alone, most dealers set the servicing to time and distance on a new car unless you ask them not to. If you got the 3 year service pack they should do anyway as that pack covers 3 annual/10k mile services and not 2 or 3 variable distance services.
Offline CraigW
« Reply #96 on: 18 October 2013, 07:39 »
I asked my dealer to change mine to annual when it was in a few weeks ago for some minor work. I got some bullsh!t excuse that they couldn't change it as it would mess up the electronics or some nonsense to that effect.
Just noticed the other day when they pulled out the dash that the MMI had been reset so when I went to check my mpg data it was saying total long journey distance 75 miles at 28.8mpg  :shocked: :shocked:
Offline shiners
« Reply #97 on: 18 October 2013, 07:45 »
MK7 XDS Adaptation channel in the ABS Module. Mine is set to Standard and I just left it at this.
Options, Standard, Not Activated, Weak, Medium and Strong.
XED by Sootchucker, on Flickr
Hi Norbreck21a, I'm new on here and have been following this thread and your work with interest thanks. A question for you - Have you tried altering the above settings to see if the ABS module will allow you to make the change? The reason I ask is that this module asks for a security code when you try to confirm you want to change the setting, for example, from Standard to Medium or Standard to Strong etc. I'm not sure how many other options in the Adoption channel for this module are security coded. My car is a Leon FR184 which shares very similar electrics to the Mk7. It could be a SEAT thing I guess but not had any issues with the other tweaks you've done.
Offline Sootchucker
« Reply #98 on: 18 October 2013, 08:06 »
Shiners, to be honest no. I just looked for someone to see if the adaptation channels were there. I don't tend to change things that affect Brake, transmission or engine in case something does wrong  :laugh:
Wonder if it's the same code as used for the Central Electronics module i.e. 31347 ?
Offline shiners
« Reply #99 on: 18 October 2013, 08:34 »
Ay, I'm with you on that score. I tend to have a look around to see what stuff can be changed to satisfy curiousity. Not surprised that feature is security coded though. Might try 31347 code, cheers.
