Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120864 times)
Offline DougL
Re: MK7 and VCDS (VAG-COM) thread
« Reply #100 on: 18 October 2013, 09:38 »
If you go to the module and click on security access, VCDS usually brings up a dialogue box with the code. At least it did for me on the 09 Central Electronics module.
Tornado Red GTI 3dr manual
Previous Golfs Mk1 GLS and GL, Mk2 GL and Driver, Mk3 GL, Mk4 GT TDI, Mk6 TDI (and a Mk2 Scirocco 20 years ago)
Offline shiners
« Reply #101 on: 18 October 2013, 09:58 »
I tried that before my initial posting and VCDS offers no security code for the ABS module.
Offline DougL
« Reply #102 on: 18 October 2013, 12:13 »
It was 40168 for the MkVI
Offline shiners
« Reply #103 on: 18 October 2013, 12:20 »
Thanks, might give that a try.
Offline GrahamFR
« Reply #104 on: 18 October 2013, 21:13 »
Depends on the vcds software your using, if it's too old it won't pop up with the right codes
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline DougL
« Reply #105 on: 18 October 2013, 21:25 »
It's the latest release. 12.12. There is still a lot of work to be done on the Mk7 by RossTech to access all the functions on the car. A lot of it is to do with communication, as different protocols are used compared to the Mk6 apparently.
Offline GrahamFR
« Reply #106 on: 18 October 2013, 22:00 »
Sorry doug, meant shiners software not yours
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline shiners
« Reply #107 on: 19 October 2013, 05:31 »
I'm using 12.12 also. Earlier versions other than 12 (Beta), won't even read modules in my FR184. I would guess the same in the Mk7s?
Offline GrahamFR
« Reply #108 on: 19 October 2013, 07:56 »
Might have to wait for next issue then, you sure you don't get a pop up box?
Another vcds change that might already be standard On Gtis but I know it's something that needs activating on other models, but do the wingmirrors drop when you put it in reverse?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline dippy_x
« Reply #109 on: 19 October 2013, 08:28 »
The wing mirror dip on passenger side is a standard feature with the GTI.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
