Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120873 times)
Offline Mark V GTD
Re: MK7 and VCDS (VAG-COM) thread
« Reply #270 on: 06 January 2014, 15:27 »
the car was pre-45 I have the wing mirrors that only unfold on ignition - really not too big a deal (as the excellent xenons soon distract me when unlocking in the dark!), but a nice to have.
All in all, great decision - thanks for your assistance!
Brilliant - glad to have encouraged you!
We are still waiting for someone witht he magic combination of haveing a post BW45 car and VCDS to post up a door controller scan. I have a hunch the unfolding on unlocking is software only so could possibly be done on a pre BW car such as yours.....
Offline jivemonkey
« Reply #271 on: 06 January 2014, 15:34 »
We are still waiting for someone with the magic combination of having a post BW45 car and VCDS to post up a door controller scan. I have a hunch the unfolding on unlocking is software only so could possibly be done on a pre BW car such as yours.....
Can't see why it would be anything apart from software...fingers crossed.
The waiting game begins then..If they could also post up the scan of the module where the camera resides (if they have one) as well that would be grand!  :grin:
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline GrahamFR
« Reply #272 on: 10 January 2014, 06:20 »
http://www.seatcupra.net/forums/showthread.php?t=393714
I have to say I'm rather jealous of the new leons mfd/fis/ display bit in the centre of the dials. More importantly is within the link above is a guide on how to change its appearance and give it a carbon fibre look. Just out of curiosity do we have any options? I'm sure it will be in the same place if we have
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline jmc
« Reply #273 on: 10 January 2014, 07:55 »
I have the  camera on my GTD, here is a full scan
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW228384
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUNA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 6283
   Revision: 81H22---
   Coding: 01190012034505082000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002006
   ROD: EV_ECM20TDI01104L906021EP_AU37.rod
   VCID: 77F9AC79CE8EF4A6A59-8022
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 633330000003D3
   Coding: 01FA8AA134220974037A060841C72980512C90C0608294F5F4605078C009
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 7BF1B049F2A6D0C6C11-802E
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 387B6F4583103BDE6C3-806D
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
2 Faults Found:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 43
                    Mileage: 84 km
                    Date: 2014.01.08
                    Time: 10:04:46
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 43
                    Mileage: 15 km
                    Date: 2014.01.07
                    Time: 07:36:12
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011333702455
   Coding: 03000A42C24122FB0BA44080B10C07281000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_VW37.rod
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    131121  042 0551
   Serial number:         131123070344
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M12D05H09M06S27S9
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY13302414R
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000058181743
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231333602858
   Coding: 0071151001
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3B717049B22610C6811-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 18111376510160
   Coding: 00000300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   ROD: EV_ACCMRRBoschVW372_VW37.rod
   VCID: 3667617D8904CDAE7EF-8063
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR022GX/
   Coding: 98CCC000000000005C0000CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F094459E6BECCE6ED9-802A
   Seat belt tensioner; left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B29111350405
   Coding: 333135
   Seat belt tensioner; right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B29111340952
   Coding: 333135
   Crash sensor for side airbag; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 003 011 13
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000582785E0Y
   Coding: 2D2D2D
   Crash sensor for side airbag; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 003 011 13
   Component: SideSensor_Pf  001 0887
   Serial number: 35867000000BCC785E0C
   Coding: 2D2D2D
   Crash sensor for side airbag; rear driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 311 13
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502A7122076092F/
   Coding: 2D2D2D
   Crash sensor for side airbag; rear passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 311 13
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502BF122076621B1
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 311 13
   Component: FrontSensor_D  001 6149
   Serial number: 35565029D1220763C050
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 28111308491518
   Coding: 0C00
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB.rod
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5G6 920 970 A    HW: 5G6 920 970 A
   Component: KOMBI         314 2210
   Coding: 27AD09002F80260001882A01040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 2E57491D7154F56E36F-807B
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001293647
   Coding: 030100040B087300EF00027E080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_VW37.rod
   VCID: 3F890459A63E0CE6AD9-806A
   Generator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130001973640063472
   Coding: 2CFFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 4843231903
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
   Component: TSG FS        020 0025
   Serial number: 24111306070085
   Coding: 003F0220D001048000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 408B07A5DBC0731ED43-8015
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000003580213
   Coding: 0D0000
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB.rod
   VCID: 356566719402C6B6775-8060
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0025
   Serial number: 19111304080721
   Coding: 003F0020DE01048000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000003560385
   Coding: 050000
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Revision: --------    Serial number: --------------
   Coding: 029E01000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 3D757E51AC321EF6BF5-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5G0 035 842     HW: 5G0 035 842
   Component: MU-S-D-ER     040 0421
   Serial number: V7E01811130693
   Coding: 02730000FF00000021111201002800001F0202160100010001
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: E2CF6D2DF50C810E627-80B7
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ702361
Address A9: Struct. Borne Sound (J869)       Labels: 5G0-907-159.clb
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0013
   Serial number: 131019200133
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: EBD1000902C6C046D11-80BE
End
VW Golf VII, GTD, manual, Night Blue, Rear view camera.
Offline jivemonkey
« Reply #274 on: 10 January 2014, 08:07 »
Brilliant! Thanks JMC. Great reference.
Offline jmc
« Reply #275 on: 10 January 2014, 14:50 »
Hi All
Is there any way of adding the low washer warning to a GTD without the winter pack option?
Many thanks
Jason
Offline JoeGTI
« Reply #276 on: 10 January 2014, 15:02 »
Hi All
Many thanks
Jason
It should be there already, if you have xenons which I assume you have.
Offline jivemonkey
« Reply #277 on: 10 January 2014, 15:05 »
Hi All
Many thanks
Jason
Yep, the only addition that winter pack brings is the heated seats (money well spent IMO  :cool:) - the rest is standard with xenons as JoeGTI says - in UK market at least.
Offline jmc
« Reply #278 on: 10 January 2014, 15:07 »
Hi All
Many thanks
Jason
Ok cool cheers for that
Offline JoeGTI
« Reply #279 on: 10 January 2014, 15:18 »
It's pretty annoying and distracting when it does come on. A big orange exclamation mark stays lit in the dash... which is the whole point I suppose.
