Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120874 times)
Offline zoom_cool
Re: MK7 and VCDS (VAG-COM) thread
« Reply #1040 on: 04 July 2016, 22:36 »
Can we make the Discover Media SAT Nav display Climate info Like my old Passat CC
Golf GTD Carbon Grey, with Leather,Discover Sat NAV,Winter Pack,DSG 5 Door
Offline p3asa
« Reply #1041 on: 04 July 2016, 23:09 »
You can get climate info if you push the set-up button
Offline zoom_cool
« Reply #1042 on: 04 July 2016, 23:27 »
It was nicer to get it to display on adjust the climate automatically I guess I will just have to press the setup button
Offline GeoBog
« Reply #1043 on: 02 October 2016, 18:20 »
It seems like the VW chaps have changed the coding of the voice control button for the cars without voice control. On my 2014 GTI the voice control button would pause/mute the music however on my 2016 GTI the button does not pause the music, it only shows that stupid message and that's about it. Does anyone know if it can be coded with VCDS to pause the music?
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline dv52
« Reply #1044 on: 03 October 2016, 07:53 »
GeoBog: Duplicate post - so duplicaste reply!
The VC function (VW call it "Speech Dialogue System") on a MIB is enabled/disabled by Bit 1 on Byte 24 (see screenshot below).
From my experience with MIB1 units, I've found that the "stupid message" that you describe results whenever this Bit is enabled and the VC software is not installed. My suggestion is that you look in the control module @ address hex5F in your car - if this Bit is set, remove the tick.
But as I recall, when the VOICE button is pressed and VC is not present, the effect is to mute the sound - it doesn't "pause the music" as you suggest
Don
103TSI Highline ROW (my13)
Offline djwoody
« Reply #1045 on: 15 October 2016, 16:38 »
When I take my seatbelt off, my Mk7 puts the parking brake on. Is there any way to change this?
Also, can you change a setting so you don't have to press the brake to move from P to D on the DSG?
Chris
Offline mcmaddy
« Reply #1046 on: 15 October 2016, 22:14 »
They are both safety features so I would say it's not possible.
Offline dv52
« Reply #1047 on: 15 October 2016, 22:28 »
Chris
woody: Hi.
Seatbelt link to Brakes:  Go to the ABS module (@ address hex03) and navigate to the adaptation channel MAS02666-Seat belt buckle scan. The factory setting for this channel is activated, change not activated. If you need a security number then try one of those that I list HERE
Brake interlock to Park
: I don't know, but I suspect that the interlock is in the tranny control module firmware - not something that VCDS can access
Don
« Last Edit: 15 October 2016, 22:38 by dv52 »
Offline djwoody
« Reply #1048 on: 16 October 2016, 14:55 »
Chris
woody: Hi.
Don
I have changed the Seat belt buckle scan to Not Activated and unfortunately this has not cured it.
Offline dv52
« Reply #1049 on: 17 October 2016, 08:45 »
Chris
woody: Hi.
Don
Bummer- the title of the adaptation channel was so close to what you wanted- I felt sure that it would work. Guess the answer must be in the code-string for the ABS unit, which ain't good because there are no explanations as to what the Bits actually do.
Don
