Author Topic: Lowering springs  (Read 1759 times)
Offline GTIJas
Lowering springs
« on: 06 October 2013, 17:39 »
Hi I have the 1.8T 20v mk4. Covered 126k but been really well looked after and runs like a dream. They guy who had it before me had bilstein b4 dampers put on. All my friends have said because of this I can get just springs not cheap budget coilovers. I want to go maximum 40mm. I have seen these:
http://www.dpmperformance.co.uk/vogtland-40mm-sport-lowering-suspension-springsbr-golf-4-18-18t-19sdi-19tdi-20-23-v5-fwd-0997-p-5151.html
Now if I get these do I need to worry about anything else, such as top mounts? Anti-roll bars? Drop links?
Also if I could see any pictures of anyone who has lowered 40mm just to see the difference would be cool :)
1.8T 20v Stage 1 generic Jabbasport
<a href="http://s742.photobucket.com/user/VwjasGTi/media/20131006_131816_zpsb661ba02.jpg.html" target="_blank"><img src="http://i742.photobucket.com/albums/xx70/VwjasGTi/20131006_131816_zpsb661ba02.jpg" border="0" alt=" photo 20131006_131816_zpsb661ba02.jpg"/></a>
Offline davemk4
Re: Lowering springs
« Reply #1 on: 06 October 2013, 19:18 »
those dampers are good yes and if all in good condition will be fine with springs. depends on budget and waht you want you can get good spring and damper kits for around 300-350. GTI MK4 sit a little lower iirc comapred to normal mk4s so a 40mm lowers around 35mm. 40mm will just be ok on anti roll bars.
this is mine on koni dampers and h&r 35mm springs
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline GTIJas
« Reply #2 on: 06 October 2013, 19:23 »
Yea the b4s are in good nick, I had them checked over when I needed the tracking doing. I will go 40mm then, payday Tuesday so ill post pictures once they're done  :smiley:
Thanks
Offline davemk4
« Reply #3 on: 06 October 2013, 19:40 »
In a way i wish id gone lower but it used so much as a daily that it maybe not a bad thing considering the amoubtvof speed bumps there is round here
Offline GTIJas
« Reply #4 on: 06 October 2013, 20:05 »
yeah I know what you mean, I don't want to go too low either, especially with the lovely sumps on these mk4s
this is mine now (cant see much in pic)
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #5 on: 06 October 2013, 21:12 »
I have just got bought some 35mm h&r lowering springs from dpm performace should be here this week
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline GTIJas
« Reply #6 on: 06 October 2013, 21:41 »
Oh awesome, I looked at those, post a picture when it's done?
Thanks
Offline paulhgti
« Reply #7 on: 06 October 2013, 21:51 »
Will do will be next week end probably.i paid £118 for them
Offline davemk4
« Reply #8 on: 06 October 2013, 22:20 »
Thanks
My pic i posted is on h&r 35mm. Also they not hard they give a muxh firmer ride improve handling but you can still go over bumps etc at normal speeds :smiley:
