Author Topic: Rear LED's on a 2009?  (Read 5161 times)
Offline AaronMc
  • GTI Life..
« on: 05 October 2013, 18:24 »
Had a search but can't really find the answer!
Looking to get the Golf R LED's for my 09 GTi, but the CarSystems website says cars before 2010 may need an updated BCM.
I have factory Xenons, and another site said if you had factory xenons you wouldnt need the updated BCM, all just confusing tbh!
So has anyone fitted some LED's to their 2009, and coded them in with VAGCOM and had no further issues?
Golf GTI MK6 Manual - Tornado Red with Jacara Cloth, Monza Shadows, RNS510, Dynaudio System, Fiscon Bluetooth, Front & Rear Park Sensors, ACC, Cruise Control, Winter Pack & Xenon Lights.
Offline Rgdogg
Re: Rear LED's on a 2009?
« Reply #1 on: 05 October 2013, 19:32 »
I have a 2009 gti and fitted led lights with no problems, just a little code change with vagcom was all that was needed.
Gti, Candy White, 3door, DSG, Leather, Rear LEDs, Bluefin, Milltek, vwr intake, Focal speakers.
Offline Neil gti
« Reply #2 on: 05 October 2013, 19:38 »
same here Sept 09 xenon's and no probs with rear R leds  :wink:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline AaronMc
  • GTI Life..
« Reply #3 on: 05 October 2013, 19:57 »
Ah fantastic!!
Was it just the coding of Byte 18? Changing it to 04?
Offline dubber36
« Reply #4 on: 05 October 2013, 20:13 »
Ah fantastic!!
That is the coding for xenons. I tried that with be halogens and it buggered up the DRLs. 15 is the magic number for them, rather than 04.
Offline AaronMc
  • GTI Life..
« Reply #5 on: 05 October 2013, 20:49 »
Cheers chaps helped a lot! Just need to order them now!
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #6 on: 05 October 2013, 21:08 »
Ah fantastic!!
Didn't work with early xenons on my cars case. It made the front side lights 50% brightness.
I was in contact with rosstech for help with the codes for mine due to been rhd as I kept reading different info.
15 worked the best. There was another code that they recomend for lhd but that seemed to caused my xenons to not turn correctly.
« Last Edit: 05 October 2013, 21:15 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline AaronMc
  • GTI Life..
« Reply #7 on: 05 October 2013, 21:42 »
May be a cause of trying and seeing what works best then?
As long as something works il be happy..
Don't even mind if I was to loose the DRLs!
Offline mustard
  • Mk7 R
« Reply #8 on: 06 October 2013, 08:43 »
Here is some information, I found on VW Vortex, it gives different variations for Halogen and Xenons.
MJ2009 with BCM (03xx software)
Encoding   VCDS Byte 18 = 04
Lights go out at the tailgate opens   NO
Error message MFA   Rear fog lamp with Resistance: No
Problem with front parking light (weak light)   NO
LED tailgate light up more when braking   YES
MJ2010 with BCM from KW22/2009 (Software 0537, 0541)
Encoding   Halogen VCDS Byte 18 = 15   Xenon VCDS Byte 18 = 43
Lights go out at the tailgate opens   NO   Update on 0575 / 6 *
Error message MFA   NO   Update on 0575 / 6 *
Problem with front parking light (weak light)   NO   Update on 0575 / 6 *
LED tailgate light up more when braking   NO   Update on 0575 / 6 *
With MJ2010 / BCM 2011 from KW45/2009 (0573 & 0575 Software / 0576)
Lights go out at the tailgate opens   YES   YES
Error message MFA   NO   NO
Problem with front parking light (weak light)   NO   NO
LED tailgate light up more when braking   NO   NO
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #9 on: 06 October 2013, 09:06 »
43 didnt work correct on my 2010 RHD car which is why I contacted rosstech.
Mk6 GTI  &  Mk1 GTI
