Author Topic: mk2 8v- corrosion repair in cylinder head  (Read 1721 times)
Offline 2pac
« on: 04 October 2013, 22:43 »
hello
corrosion has eaten the cylinder head on the mating surface with the inlet manifold, so there's a recessed spot near the small coolant passage and it's leaking from there. how would you fill it up? a gasket maker? or maybe one of those epoxy sausages that repair iron?
thx
Offline Mr Blue
Re: mk2 8v- corrosion repair in cylinder head
« Reply #1 on: 05 October 2013, 00:40 »
Weld then skim bud. Machine shops can sort this :)
