Author Topic: My Turbo is very slow!  (Read 1757 times)
Offline hamps
« on: 04 October 2013, 22:11 »
Hi guys
I have a 1.8 20v turbo which just feels under powered  :whistle:
It has the AUM engine, which had a proper rebuild and a new turbo last year, engine sounds lovely, car drives real nice but it boosts at what feels like 8psi tops!  :sad:
This is my first petrol turbo Golf Iv'e had it two weeks.
It had a Forge dv on it and some pathetic excuse of an induction kit :grin:
I have purchased a standard air box and fitted that and re fitted the standard re circ valve and re set the actuator using the 3 turn method and it still feels underpowered, you can here the turbo very faintly then a little silent hiss between gear changes with the Forge dv in place!
I know it's standard but surely I should get a little kick, or some torque steer?
Any help what to check greatly appreciated  :smiley:
I plugged it in no faults present, not got vag-com because I run a mac   :undecided:
Demon Dipping UK
water transfer printing and custom refinishing specialists.
07790195006 info@demondipping.co.uk
Offline Chris#101
Re: My Turbo is very slow!
« Reply #1 on: 04 October 2013, 22:19 »
The 150s were fairly 'flat' as standard. Get it mapped will be a different car  :wink:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline hamps
« Reply #2 on: 04 October 2013, 22:24 »
OK cheers, will look into it.
I heard the N75 can fail? where is it and can I test it?
Demon Dipping UK
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 05 October 2013, 09:00 »
If you're getting 8psi it sounds like it's fine, just standard.
You won't get any torque steer even on a mapped car, I don't get any on mine
Offline Rhyso
« Reply #4 on: 05 October 2013, 11:46 »
Thats because you petrol boys cant produce enough torque  :tongue:
Offline Dave_IOW
« Reply #5 on: 05 October 2013, 12:28 »
First time I drove mine I also thought the turbo was missing :grin:
Remap fixes that, it will be the singularly best modification you do to a car.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline leigh_harty
  • Audi AGU
« Reply #6 on: 05 October 2013, 12:33 »
And the singularly best mod to start causing you problems, especially if your car is standard and your boost hoses for example are the originals.... potentially a remap can cost more than expected.
My 150 agu doesn't feel that slow unless your doing a rolling start then its just pants. rag it from the off and its still got some go! maybe I've just got an healthy engine for now  :lipsrsealed:
Dont lose your dinosaur!
Offline Dave_IOW
« Reply #7 on: 06 October 2013, 03:48 »
Problems you have prior to map will be highlighted, yes.
What else can you spend £200 on and get 50 extra HP? Even if you do have to replace your (already) failing parts?
Offline GTIJas
« Reply #8 on: 06 October 2013, 08:24 »
Agreed, hands down best purchase I've ever made for a car. £250 inc. rolling road at Jabbasport went from 148 to 203. Transformation of the car
1.8T 20v Stage 1 generic Jabbasport
<a href="http://s742.photobucket.com/user/VwjasGTi/media/20131006_131816_zpsb661ba02.jpg.html" target="_blank"><img src="http://i742.photobucket.com/albums/xx70/VwjasGTi/20131006_131816_zpsb661ba02.jpg" border="0" alt=" photo 20131006_131816_zpsb661ba02.jpg"/></a>
