Author Topic: Automatic transmission oil leaking....coolant also disappearing...oh no....  (Read 4189 times)
Offline Jasikasisback
Please take a look at these pictures as they say it all..
I let my car sit for about 6 weeks...came back and had some white smoke leave the tailpipe on startup...thought maybe from it sitting around too long...
However when I looked at the engine compartment I saw what was in the photos....
http://www.flickr.com/photos/67897318@N06/
O I hope the above link works...
Some coolant loss as well...I believe it is mixing with the tranny oil..:(
My friend said that radseal will solve the problem....is it worth a go???
I am reading on the internet that you can use black pepper as a sealant???is this for
real?wow who has tried this??
« Last Edit: 05 October 2013, 12:54 by Jasikasisback »
Offline Luke1981
Never heard this before.
I don't understand how the coolant can be mixing with transmission fluid though
MK IV GT TDI 150 PD / MKII CADDY SDI
Look at your expansion tank..there is a hose going down to the top of the transmission box..(on the automatic version anyways) this cools the transmission oil..) if you look at the pictures I have put up you'll see that the oil is coming out of that box...so I most likely have a leak...I figure if I plug the leak then it will hold for some time....just afraid that it might get into the transmission and destroy it...:)
VW BUSH
I would say you are leaking coolant into the box and this is pushing out the oil.....
you might wanna fix that :grin:
yeah that is what is happening for sure...when I drove it daily the water would "evaporate" due to the heat...so I guess I will try the radseal....if not I will need a new automatic transmission box...which is more than the car is worth....(I have had no luck finding a scrap automatic golf for parts...)
Will give it a go with sealant or just try the pepper thing as it appears to be the least harmful...
Of course if it goes into the transmission box...then bye bye car....:)
This problem was probably the reason that the car was sold to me three years ago...
Initially the transmission fluid was low and we replaced it...but there was no evidence of a leak in the the sump or anywhere else...car seemed to run fine for half a year...but the transmission became less responsive as time went on....
replaced transmission fluid again a year later as the level went down slightly....
then last winter the car smoked upon startup in the winter....totally crap...where is it coming from?
I got the engine and water system pressure tested by a forum member here and he stated there are no leaks...this is when the car is warm....(after 10 miles of driving)
Now this year the coolant went clear...and after the car stood for 6 weeks without me driving it the evidence of the oil leak on the transmission coolant block is now evident..
So I have a small leak somewhere in the system that disappears when the car warms up....joy oh joy...
But I believe this was the reason my car used to smoke in the winter and it has survived for almost a year in this state.....as it was burning off the excess oil....or water or whatever the hell it was....
So there is a leak of transmission oil into the coolant system and maybe a coolant leak as well...
It appears the car is on it's own deathbed as it will cost more than I can spend to save it.....
So advice please...if i try radseal will if kill the car or is it a possible go?
Guess what I am afraid of is that the excess water now at least has a way of burning off...if I trap the excess water in the transmission box...then when it expands it will the box??...and end of tranny...perhaps I should drive the car and burn all the excess water let it cool down somewhat and then stick the radseal in???but then if the leak is only evident when the car is stone cold it wont seal any crack....unless I put it in when it is stone cold (which may not allow it to work...) and thus catch 22....:)
I am in a bit of a problem here...unless someone has an 01M automatic tranny box and cooler lying around and feels generous...only in fantasy land i think....
I will always remember VW service center telling me that these transmissions are indestructible and never need any maintenance...hmmm...
The joys of owning a VW.....:) learned more about how they work than I ever imagined...:)
« Last Edit: 06 October 2013, 01:37 by Jasikasisback »
« Last Edit: 06 October 2013, 01:28 by Jasikasisback »
VW BUSH
Have a look at how it cools the oil.
Take the cooling connection off and join it together.
Cap the box connections.
Flush and replace atf.
I ran a V6 auto like this for quite a while, towing and trips to Europe are out but it might keep you going for a bit. ...
Depends on how fcked the box is.
the transmission is still functioning. I will give sealant a go i think.
