Author Topic: Dash LED  (Read 2210 times)
Offline Mcwill
Dash LED
« on: 03 October 2013, 12:53 »
Got an led kit and can't get it working.
This did not work
This is what came in kit
Any help would be great  :smiley:
Offline Diamond Hell
  • Opinions я Us
Re: Dash LED
« Reply #1 on: 03 October 2013, 13:47 »
Solder the LED back in the opposite way round?  IIRC they only work in one current direction?
Offline molegti
Re: Dash LED
« Reply #2 on: 03 October 2013, 15:00 »
If the resistor is on the + side then that LED is definately the wrong way round. The cathode (-) is the shorter leg (before you cut it :) )
Offline Mcwill
Re: Dash LED
« Reply #3 on: 03 October 2013, 16:16 »
Thanks guys
Offline Mcwill
Re: Dash LED
« Reply #4 on: 03 October 2013, 20:27 »
Back again :smiley: just tryed to do one of the 2 bulb switches, no joy :tongue:
Thought I had done it correct?
Offline JMallows
Re: Dash LED
« Reply #5 on: 06 October 2013, 12:50 »
As said diodes only work in forward bias (in this case anyway) so you need to make sure you get the supply leads right (short leg cathode and also the part of the led 'lens' with a flat side is the cathode in case you've already cut the legs). Also, if you have got the connections the wrong way round and are resoldering them, be aware that LED's are also static and temperature sensitive, so you could have destroyed it by getting it too hot with additional soldering on short legs.
You can test the LED with a multimeter - use it on conitinuity setting and it will glow when forward biased.
A clever person solves a problem. A wise person avoids it.
