Author Topic: How do you put a speedo with a rev counter on a car that dont have 1  (Read 2512 times)
Offline dasachmo
just a quick q, i got a mk 2 golf, and it dont have a revcounter, and im getting a GTI clock, and im just wondering, where do u connect the bit that detects the revs, if the orginal clock never had one?
Offline monzablue16v
Hi Mate
It should have the lead already on the plug Germans are good like that ;) bless em engineering geniuses!  :grin:
If not the rev counter runs from the the coil
Hook the power wire up to an accessory feed. Earth/Ground wire to a metal part of the body. Illumination wire to the side/head light feed. The Engine speed wire low to the low tension small positive + lead on the coil should only be 12v use a meter 1st. And hey presto, one Tacho. ;)
« Last Edit: 20 August 2005, 00:10 by monzablue16v »
Fielder5757
My rev counter runs from the coil.
Offline mikegolfgti
back in the days when i had a 1.3 the gti dash plugged straight in and worked straight away, like monza said most of the wirings in the cars already  :smiley:
Offline spacedGTI
depends what spec really? I mean if a 90 spec probably the plugs there if a older model no?
Offline dasachmo
well,  its a B reg 85 golf, mk2,
i have a A reg 84 scirocco rev couinter, but i aint 2 sure on these 2 cars compatibility, coz the rocco seats do fit, but dont slide freely in the golf, so i had to buy some other ones to get thru the MOT.
thinking of getting a GTI clock, coz thas the safest bet, just looking around, ma mate got one from a scrappie in cov for a tenner
Dont matter what year MK2 the rev counter wiring is already in place, as the dash needs the rev signal for the oil pressure buzzer.  All you have to worry about is getting the right type of clocks, older models with the hazard switch on the dash have 2 plugs to the dash clocks, whilst newer models with the hazard switch on the steering column have 1 plug.
I'm pretty sure MK2 Scirocco clocks are the same as MK2 Golf clocks, but I might be wrong on that one.
Offline dasachmo
yeh, i think in the other post i asked, but then the rocco seats were meant to fit the golf, and they did, but the sliding mechanism didnt owrk properly, the peg that locks the seat into place wouldnt engage coz of the difference in the handle from the golf and rocco, so had to take them out coz it wont MOT if the seat dont move fully forward and back,
so just a lil wary before i start taking out bits and bobs outta the rocco
bit strange tbh, always been lead to believe it was a straight swap!
Offline Ozz
Rocco seats are a straight swap, got them in my car and they work fine, just takes a bit of fiddling as they sit so low, its hard to get everything in and lined up right. Once in they work fine and slide like normal.
Mk2 Gti 8v
