Author Topic: Water leak  (Read 2147 times)
Offline Mcwill
Water leak
« on: 30 September 2013, 15:58 »
Hi guys, got water leak on me 8v golf, looks like its coming from behind the cambelt casing so rec its water pump?
Is that a big job or is it something I could do myself? Not to bad at diy.Also does it mean i have to remove the cambelt.
Any help would be great :smiley:
Offline Jimmyrallye
  • 20vt goodness
Re: Water leak
« Reply #1 on: 30 September 2013, 16:28 »
Hi waterpump/aux belt don't run of cambelt so your be fine .. It's quite a easy job hardest part for me wos getting the old bolts out the water pump that go in to block as they was well stuck in there apart from that it's not that bad
Offline Mcwill
Re: Water leak
« Reply #2 on: 30 September 2013, 16:42 »
Thanks for that mate, how long did it take you to fit it?
Offline Jimmyrallye
  • 20vt goodness
Re: Water leak
« Reply #3 on: 30 September 2013, 21:19 »
Couple of hours to make job easiar get some juba lee  pliers your need them for all the pipe work
Offline oakgreener
Re: Water leak
« Reply #4 on: 01 October 2013, 10:37 »
As said, easily do-able. I found it easier to get a few screw type hose clips, 40mm diameter I think, as the springy ones are a ball ache to wrestle with. Get a new therostat as well, and I fitted a new bottom hose at the same time.
Offline Gambit
Re: Water leak
« Reply #5 on: 01 October 2013, 10:41 »
aye the springy ones are a complete ball ache. pointy nose vice grips are handy for removing them
Offline Mcwill
Re: Water leak
« Reply #6 on: 01 October 2013, 14:31 »
Thanks guys
