Author Topic: Enable Chirp with VAG.com  (Read 1547 times)
Offline martininwillerby
  • Golf GTD DSG
« on: 30 September 2013, 12:51 »
Hi...
Not been on here for a while, but I now need your help...
I've now got a mk6 GTD (may 11 build). I've had it into a garage to have the chirp enabled via VAG.com
And they seem to have done it but it's very quiet, to the extent that the locks on the door locking are louder than the chirp.
I've had the sweep of the needles enabled and that's fine.
I would like to disable the seat belt chime and last of all have the speed displayed in MPH large in the middle of the DIS like Audis are...
You help will be much appreciated.
Thx
Martininwillerby
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
Offline RocketRossUK
Re: Enable Chirp with VAG.com
« Reply #1 on: 30 September 2013, 16:19 »
I have done all of the above on mine, cant remember which section and block it is, will have a look when i get home.,
But yeah, in regards to the chirp its not very loud at all, half the DB's compared to my MK5.
  • Golf GTD DSG
« Reply #2 on: 30 September 2013, 18:16 »
Oh well at least I know it's not a fault with the car...
Martininwillerby
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 02 October 2013, 17:55 »
Chirp is very quiet as is the alarm siren itself.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Keithuk
« Reply #4 on: 02 October 2013, 21:19 »
Seat Belt Chime/Reminder
Now I never drive without a seat belt but there are a couple of occasions when the beeping becomes annoying. When I goto the supermarket I take a bag of bottles/jars for the bottle bank. I drop them in the bins and get back in to drive and find a parking space and it keeps on bleeping away. When I drop off my drinking buddy here unclips his belt has we are coming upto his house which is only 30 yards but it bleeps away again.
Navigate to 17 - Instruments
Select Coding - 07
Select Coding - Long Coding
Continue with arrow down on keyboard until Byte 1 is showing then untick Bit 1
Then back to the main window and click the Do-It button, a message coding accepted will show. Its the bleep I wanted to disable but this does both the bleep and the warning light.
Now any coding you change is saved to \Ross-Tech\VCDS\Debug\CodingLog.TXT so at least you have a file with any coding changes you have made so you can change the numbers back if need be?
e.g. Seat belt
Quote
Address 17:5K6 920 970 E recoded (Long Coding) from 470B00 to 470900 (01357/011/00200) Monday,25,April,2011,15:25:41:21184
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
