Golf mk4
Wazzzer
quick front strut brace question
Topic: quick front strut brace question (Read 1427 times)
davemk4
29 September 2013, 21:34 »
Read the guide looks simple.... tge link to seller is out of stock . So found some others on ebay JOM etc but they list them gor 1.4 1.6 1.9tdi. I thought all mk4 struts were same?
Anyone know if these fit the 1.8T?? Links if you be so kind
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
brewey
Re: quick front strut brace question
29 September 2013, 22:40 »
Get the s3 brace instead, it's OEM and definitely fits the 1.8t bay.
You can pick them up dead cheap if you look around. Mine cost 30quid delivered.
2000 1.8T ARZ - OEM+
sveed1.8T
30 September 2013, 01:29 »
S3 strut brace FTW
1995 1.4 Golf Match
2000 1.8T Golf
2001 115PD Golf GT TDI
2009 Scirocco GT TDI 140 DSG
davemk4
30 September 2013, 06:57 »
No s3 ones on ebay apart from pattern ones.... but intresting that the non gen ones would fit mk4 golf but if you search for mk4 golf thd same pattern braces are for na and tdi only?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
30 September 2013, 12:29 »
It's probably due to the engine cover
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
davemk4
03 October 2013, 15:31 »
Got one sorted a JOM one lines up mint does push on dv though may require some tinkering
Golf mk4
Wazzzer
