Author Topic: exhaust help  (Read 1766 times)
Offline wsmith
exhaust help
« on: 29 September 2013, 13:15 »
my middle box has started to blow so when i had the car on the ramps to check i noticed that the middle section and backbox is all one peace so how will i get it off the car as it goes over the axle , my car is a remapped 1.8t with a decat and org exhaust im thinking if i cut the middle box out and put a pipe in its place will it be ok with the standed backbox
Offline dom
  • Back in a Mk4
Re: exhaust help
« Reply #1 on: 29 September 2013, 13:51 »
You either have to cut the exhaust or drop the rear beam to remove it.
It'll be fine if you remove the middle box and keep standard back box :afro:
Offline wsmith
Re: exhaust help
« Reply #2 on: 29 September 2013, 14:09 »
cheers i think i will just cut the box out
Offline gm8
Re: exhaust help
« Reply #3 on: 29 September 2013, 18:41 »
original exhaust is 2 piece , joined by a sleeve
Offline northeast_gti-t
  • "1.8T AGU"
Re: exhaust help
« Reply #4 on: 29 September 2013, 19:25 »
Just as dom says both easy enough jobs to do but cutting the exhaust would be quicker :afro:
2000 Mkiv GTi 1.8T AGU
Offline wsmith
Re: exhaust help
« Reply #5 on: 29 September 2013, 19:36 »
i thought that but mine is all one bit from the cat ,im just going to cut the box out as after xmas im going for a better exhaust and dont want to waste money buying a new std exhaust cheers for the replys
Offline dom
  • Back in a Mk4
Re: exhaust help
« Reply #6 on: 30 September 2013, 11:27 »
Not the section of the exhaust that the OP is referring to. The standard exhaust is 1 piece from the cat to the back box.
Offline GTi_James
Re: exhaust help
« Reply #7 on: 02 October 2013, 09:12 »
+1 i had to cut off my exhaust as it was one piece and never replaced since the car was purchased
