Author Topic: Heating probs on my Golf mk4 gti 20v  (Read 2036 times)
Offline deanos69
« on: 28 September 2013, 12:26 »
I just cant go another year with only luke warm heating, iv done every think I can think of to try and fix the prob but nothing seems to solve it. first I changed the thermostat and tested it before I put it in, I then run out any air too, but this has not worked, then I got my mechanic to flush out the matrix but he said it was running fine so still no joy , then I had all my cam belt and tensioner and upgraded my water pump but still no joy I even took it to a vw macanic and he said he could not understand what it could be. iv had the car for 10 years know and want to keep it as I have looked after it but at the point where if i cant fix it ill have to let my poor car go. can any one help
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Heating probs on my Golf mk4 gti 20v
« Reply #1 on: 28 September 2013, 12:47 »
Is the low temp reflected through the temp gauge or just the actual heaters mate? Is it reading below 90 degrees?
Offline deanos69
« Reply #2 on: 12 October 2013, 16:48 »
just the heating in the car when I turn it on when the car is at temp  the heating is still luke warm
Offline Gti_Jamo
« Reply #3 on: 14 October 2013, 17:22 »
Could be a blocked heater matrix. If you can locate the two pipes that go to it through the bulkhead, with the engine upto temp, check for any noticeable variation in temp between the two.
Offline gazareth
« Reply #4 on: 15 October 2013, 17:56 »
change your cabin filter (if fitted)
