Golf mk4
Wazzzer
Is there a guide to replacing turbo on here?
Topic: Is there a guide to replacing turbo on here? (Read 1401 times)
M.sheldon23
27 September 2013, 10:26 »
Could do with a guide to replacing the turbo before I get sock set out?
M.sheldon23
Re: Is there a guide to replacing turbo on here?
27 September 2013, 12:02 »
It's a 1.8t agu engine..
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
27 September 2013, 18:24 »
There might be a link in the maintenance section, if not there is definitely one on ukmkivs that I can link you to later
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
M.sheldon23
27 September 2013, 19:32 »
If you can find me a link pal would be good. Am struggling to find one. An a really need to start it tomorrow. Got a turbo pissin oil every where looks like cars on fire sat at lights.
Chris#101
27 September 2013, 19:58 »
Didn't look very hard
Second link down is the one you want its the one wazzers talking about
https://www.google.co.uk/#q=uk+mkivs+turbo+how+to
It's the one I used the first time I removed my turbo. It's a fairly simple job, few fiddly bits
Good luck
2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I : PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
M.sheldon23
27 September 2013, 20:21 »
Just a lazy grit Chris.
But a ment couldn't find one on here.
Cheers though! Spanners out in morning.
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Reply #6 on:
27 September 2013, 22:14 »
It's not a hard job, just the lack of space makes it a bit of a PITA
Golf mk4
Wazzzer
