Author Topic: rtech remap  (Read 3214 times)
Offline chubbz1005
rtech remap
« on: 25 September 2013, 22:04 »
hi got my car booked in for a stage 2 currently running forge tip decat pipercross filter milltek catback forge 007 gonna do the n249 bypass before i go im currently showing three error codes 2 for the ,issing lambda and the 17705 which i cant shift what happens if they cant do my car do i still have to pay? thanks chri also is there anything else that i should do before the map
Offline Scott D
Re: rtech remap
« Reply #1 on: 26 September 2013, 17:19 »
long as the codes are definitely down to decat and 17705 a bug with the ECU software not an actual leak should be ok
check all hoses for leaks, plugs, coilpacks. I took spares down just incase but no issues  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
