Author Topic: Interior felt sunroof trim  (Read 3581 times)
Offline Brads MK2 GTI
« on: 25 September 2013, 09:29 »
Hi there - just reupholstered my roof liner as per the guide in the sticky (excellent write up by the way, much thanks) and happy with the result.
The problem I have is how for the love of god does the interior sunroof trim go on, the felt tube thing?? I've tried and it just won't go :-( Does any one have any advice, perhaps pictures?
On the front corners (towards the screen) does it have to go under the front sunroof plate where the deflector arm is screwed on? If so how??
I should have paid more attention to how it was sat before I took it off but I didn't think it'd be such a mare
Offline Sgt_Lemon
  • 8v owners club
Re: Interior felt sunroof trim
« Reply #1 on: 25 September 2013, 15:12 »
The seem goes towards the back and is in the middle. From there chose a direction and start to push it into the lower edge, it's awkward trying to get the lining in their so I pushed that in afterwards with a flat head. You will have to quickly to remove the sunroof spoiler thing just so you can access the corners easier.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 25 September 2013, 18:07 »
To confirm, we are talking about the felt "U" section trim, that finishes the sunroof aperture off on the interior of the car, ie, just above your head when you're sitting in the car?
Does it not hold in place, too loose, or is it too tight?
Have you tried banging it on with a rubber mallet?
Thom
Offline Mr Blue
« Reply #3 on: 25 September 2013, 18:08 »
You might have to lift the sunroof rails off. I always do it this way.
Trim goes under the rails yes.
Edit: With thicker material its slightly tricky. Just have to use more pressure and it should grip. I always start at the middle back.
« Last Edit: 25 September 2013, 18:14 by Mr Blue »
Offline Thom89
« Reply #4 on: 25 September 2013, 18:14 »
I've just clicked :grin: as above!
Carry on, nothing to see here...
Thom
Offline Lewy
« Reply #5 on: 25 September 2013, 18:23 »
Oh dear Thom......
"JV, I think we's got ourselves an imposter......."
Offline Mr Blue
« Reply #6 on: 25 September 2013, 19:08 »
Such a newby that Thom. What does he know about stripping and fitting cars  :rolleyes:
Offline Thom89
« Reply #7 on: 25 September 2013, 19:21 »
Bad at the Office :wink:
Thom
« Reply #8 on: 27 September 2013, 15:18 »
Ay I got it sitting nicely all the way around after lifting the sunroof front up after loosening it, the only trouble is on the front long section (closest screen) it doesn't seem to grip at all, far too loose? I was considering a bit of silicone over the metal rail to give it a bit more girth(!) as I didn't want to glue it or anything that will cause a problem if it needs to come off.
Offline Sgt_Lemon
  • 8v owners club
« Reply #9 on: 27 September 2013, 16:54 »
Why won't it grip? when the corners are in nice and tight it would hold in place the straight section. The increased thickness of head lining should give it something to grip onto also.
