Author Topic: mk5 gti DSG - rattle sound from engine bay  (Read 5405 times)
Offline mac456
« on: 23 September 2013, 15:07 »
Hi,
I have only just got my car and so far I really like it.
The one thing I have noticed though is that there is a rattling sound from the engine bay area when either letting off or just idling the engine.
If I apply some acceleration to the car it is fine, sound goes away.
Any ideas? is it normal? doen't seem to effect the drive at all.
Edit: I have just read on another forum that the type of fuel used can cause these symptoms (the fuel pump is making the sound) and using 98 ron solved the noise/rattle. I will try this tonight (the car is currently sitting with a small amount of 95ron in it)
« Last Edit: 23 September 2013, 16:24 by mac456 »
Offline Poached
Re: mk5 gti DSG - rattle sound from engine bay
« Reply #1 on: 23 September 2013, 17:33 »
Was your car bought from a Garage or Private sale?
Offline mac456
« Reply #2 on: 23 September 2013, 23:07 »
Garage, 3 month warranty? Big problem?
Offline Poached
« Reply #3 on: 24 September 2013, 17:03 »
You could have the car scanned and looked over and then take these results to the supplying garage and have it covered under warranty if it's faulty.
Offline mac456
« Reply #4 on: 24 September 2013, 17:28 »
I have done that today, I took it to a Vw indy garage this morning and they think the sound is coming from the cat.
I told this to the delear and they don't want to know so looks like I am going to have to go to trading standards for this one. so much for 3months warranty!!!
Any idea how much a new cat is on these? my VW indy thinks alot because there is two of them. Is there a alternative or anything?
Offline Poached
« Reply #5 on: 24 September 2013, 20:11 »
There's 3 cats on the GTI.
The pre-cat is only installed for start up emissions so has no bearing on a current MOT. You could remove this first and see if it removes the rattle? Will improve performance a little too.
If the car did need replacement Cats I would just put an aftermarket exhaust on with a sports cat, be interesting to see a comparison of costs.
Is the warranty supplied by the garage or is it one of these AA or RAC warranties flogged by the garage? Read the Terms carefully, they can't just tell you to get lost if it's in the policy.
Offline mac456
« Reply #6 on: 24 September 2013, 20:54 »
It was supplied by the garage. It was the cat nearest to the engine, is this one? Would a exhaust shop do this for me, removing the pre cat? Do you know if it will leave warning lights on the car?
« Last Edit: 24 September 2013, 21:00 by mac456 »
Offline Poached
« Reply #7 on: 24 September 2013, 21:05 »
Well a tuner would knock it out, that's how mine was and many others have been removed.
The emissions test is done when the car is warm so the pre-cat is null.
Should not throw an error code.
« Last Edit: 24 September 2013, 21:37 by Poached »
Offline mac456
« Reply #8 on: 24 September 2013, 21:27 »
Cheers ill check it out over the weekend. Do you think it is the nearest to the engine?
Offline Poached
« Reply #9 on: 24 September 2013, 21:36 »
Hard to say but it won't cost a lot to remove or inspect.
Who knows, it might not even be in situ :laugh:.
