Author Topic: H & R springs (now with pics)  (Read 2300 times)
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« on: 22 September 2013, 23:26 »
A has any one used h & r lowering springs on their golf? Had my car on the ramp at work and found i got a broken rear rear spring so in thinking of getting some 35mm lowering springs.dont know if they will rub in the arb im running 17" santa monicas.just wanted to know if they will be quite a hard ride thats all.cheers.paul
« Last Edit: 11 October 2013, 09:17 by paulhgti »
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline Damian @ DPM
  • DPM Performance
Re: H & R springs
« Reply #1 on: 23 September 2013, 12:26 »
One of the best suspension brands out there and you'll be fine with the standard ARB and a 35mm drop.
Only thing to think about is changing the shocks at the same time.
Damian @ DPM Performance
DPM PERFORMANCE
The premier online suspension and handling specialists!
www.dpmperformance.co.uk
0191 2816844
sales@dpmperformance.co.uk
http://www.facebook.com/pages/DPM-Performance/208281640681
Offline davemk4
Re: H & R springs
« Reply #2 on: 23 September 2013, 22:08 »
Im on h&r springs wuth koni shockers. Firmer ride but still normal for a daliy
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline paulhgti
Re: H & R springs
« Reply #3 on: 23 September 2013, 23:02 »
Cool thats what i wanted realy cheers mate.paul
Offline davemk4
Re: H & R springs
« Reply #4 on: 24 September 2013, 22:15 »
thats why i went for the set up £275.00 and came with h+r springs and koni shockers in the box works great on th bends and is firmer over bumps etc but still perfectly fine for a daily runner
Offline paulhgti
Re: H & R springs
« Reply #5 on: 25 September 2013, 09:03 »
Cool i shall try and order them this week ill fit them at work i got a ramp i can use.when they are on i will post some pics up
Offline paulhgti
Re: H & R springs
« Reply #6 on: 09 October 2013, 16:14 »
Look what the post man delivered today
Going to try fit these at work tomorow if i do i will post pics
Offline davemk4
Re: H & R springs
« Reply #7 on: 09 October 2013, 20:11 »
good choice that.!!! glad you got em
Offline paulhgti
Re: H & R springs
« Reply #8 on: 09 October 2013, 21:01 »
Same had to come from germany so took a while to get here.just hope my boss is in a good mood tomorow and let me fit them or its the deive way on saturday haha
Offline paulhgti
Re: H & R springs
« Reply #9 on: 10 October 2013, 17:37 »
Well got them fitted wasnt to bad realy o/s/f was a pain tho
Just took a few pictures while at work.has any body found that after lowering there car the brake pedal feels a lot harder?cheers.
Front
Rear
Still got to settle down yet
