Author Topic: LHD xenon headlights  (Read 6007 times)
Offline pryda
« on: 22 September 2013, 18:25 »
whats the deal with fitting LHD headlights to a RHD car? I'm desperate for a pair of xenons, but all I can find on ebay is LHD versions from germany and america.
can these be fitted with some mods?
cheers
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline spiderman
Re: LHD xenon headlights
« Reply #1 on: 22 September 2013, 19:21 »
I can't see any real reason why they would be built differently? Hopefully someone will know if they are.
I would have thought it would just be the positions of the beams, you can adjust those with a 6mm hex key (both up and down and left and right), although i also believe if you re-calibrate the system with VAG-com on level ground it will sort it out itself.
We discussed it at work before i re-adjusted my lights and the concensus was if you disconnected the position sensor on the LH rear suspension wishbone and then plugged it back in then it would probably re-calibrate itself as well. I haven't tried it so don't quote me :tongue:
I opted for the Manual adjustment with the hex key for setting height (which was my issue) and it was simple and quick. White does up and down and black does left to right, all you need to do is work out the positions before removal and then set the new lights to the same post installation.
I hope it is this easy or if there is a reason it won't work hopefully someone knows.
Good luck
Sandy
Looking something classic
Offline neils mk6
« Reply #2 on: 22 September 2013, 20:58 »
ive just had xenons with dtl fitted on mine & I love them the standard headlamps are crap so while expensive they just make my car look great & they work ace !!
Offline dubber36
« Reply #3 on: 22 September 2013, 21:29 »
There is more to lhd/rhd adjustment than just up and down and left and right. The lenses are different so that dip beam has a kick up to the ditch side. I will stand corrected on this but I'm pretty sure when you adjust rhd headlights into travel mode for driving on the right, you get a flat beam as opposed to a true lhd beam.
Offline mike.
« Reply #4 on: 22 September 2013, 21:49 »
Yep I would say you are right dubber36.
RHD:                  \__\__
LHD:                  __/__/
TRAVEL MODE: _____
Basically you would be blinding oncoming traffic with the LHD units unless you had them in travel mode all the time.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Eeef
  • Lord of War
« Reply #5 on: 22 September 2013, 21:56 »
Fit right hand drive ones and make sure you fit the ballast/auto leveling as well, otherwise they're illegal.
Offline pryda
« Reply #6 on: 22 September 2013, 22:05 »
I had a feeling it wouldn't be a quick fix.
someone sell me their xenons lol
Offline Candy Man
« Reply #7 on: 22 September 2013, 22:14 »
Ive got  xenon lhd lights fitted and adjusted to suit my rhd car. So far so good, beam pattern
Seems same as my m8s rhd lights, a few peeps on here are running the lhd with no issues. Hth
Offline dubber36
« Reply #8 on: 23 September 2013, 07:47 »
Hazzy Dayz will supply and fit OEM lights for £1710 all in http://www.hazzydayz.com/genuine-vw-golf-mk6-xenon-headlight-upgrade-174-p.asp but that is without washers and leveling. If you also want LED xenons, you will also need rear LED's. Your plug and play copies won't do, as the car needs to know it has LED's fitted. As yours have resistors in them to confuse the bulb out warning system, your car doesn't know anything is different.
£1710 is a monumental amount of money, but to put it into context, it's only around 4 months of PCP drip that many Mk7 owners will be paying to ride round in their new cars.
Personally I wouldn't bother. I bought a B7 Passat Sport earlier this year with every intention of retro fitting all the bits that I would have liked to have speced had I bought a new one. Now it's come down to parting with the money, I can't bring myself to do it. I'd rather save the money and by the next car with all the bits on from the start.
Offline pryda
« Reply #9 on: 23 September 2013, 11:39 »
you can pick up a set of genuine RHD xenons from VW for 900 quid. so looks like hazzydayz are looking to rip off customers (unless they want to justify charging 800 quid for fitting!)
I'm looking for a decent set of used lights for around 400-500.
« Last Edit: 23 September 2013, 11:41 by pryda »
