Author Topic: options for mk4 rear beam bushes upgrade?  (Read 2984 times)
Offline davemk4
« on: 22 September 2013, 14:54 »
rear beam bushes have gone. any reccomendations for a upgrade while changing? audi TT ones i think are better than oem are they not or am i wrong? or is it just worth putting normal ones back in?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Rhyso
Re: options for mk4 rear beam bushes upgrade?
« Reply #1 on: 22 September 2013, 15:49 »
TT bushes are for the wishbones
Fabia vRS bushes is what you want for the rear beam
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 22 September 2013, 15:51 »
as above :afro:
Offline davemk4
« Reply #3 on: 22 September 2013, 15:52 »
thanks  :smiley:
Offline davemk4
« Reply #4 on: 22 September 2013, 15:54 »
oem or poly bush though? poly bush ist them as same part number. or is the oem vrs a better spec than golf oem?
linky be great :)
Offline Rhyso
« Reply #5 on: 22 September 2013, 17:06 »
Fabia is a more solid rubber, better than Golf; not as harsh as polybush
Helps they are about the same / cheaper than OEM Golf ones
Local dealer is your best bet  :smiley:
Offline davemk4
« Reply #6 on: 22 September 2013, 17:11 »
thanks.
if im feeling flush are the poly ones worth the difference?
Offline Rhyso
« Reply #7 on: 22 September 2013, 17:25 »
thanks.
Not really. I wouldnt waste your money
Offline davemk4
« Reply #8 on: 22 September 2013, 17:28 »
 :cool:
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #9 on: 22 September 2013, 20:28 »
I put polly bushes in mine as i put them in the front but i find it quite a stiff ride but handles better
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
