Author Topic: Service kit  (Read 2475 times)
Offline Mark b
Service kit
« on: 18 September 2013, 02:07 »
Anyone know where I can buy a service kit from for my 2.0 petrol
Standard gti 2.0 115bhp 2000 w reg
Offline sharki786
  • GOT BOOST??
Re: Service kit
« Reply #1 on: 18 September 2013, 06:10 »
You mean oil fiter oil and all that? Local motor factors??
Or try tps (if they serve you) or go to vw
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Rhyso
Re: Service kit
« Reply #2 on: 18 September 2013, 09:08 »
VW are as cheap for service parts as your local motor factors. You know you are getting genuine stuff too  :wink:
Offline Mark b
Re: Service kit
« Reply #3 on: 18 September 2013, 10:01 »
Cheers for the advice appreciated not long changed the pollon filter just needed the rest
Offline dom
  • Back in a Mk4
Re: Service kit
« Reply #4 on: 18 September 2013, 10:49 »
I also get my service parts from VW :afro:
Offline mcgee9t2
Re: Service kit
« Reply #5 on: 18 September 2013, 12:59 »
vw or tps, only place i get any parts from (bar uprated after market parts)
Offline Mark b
Re: Service kit
« Reply #6 on: 18 September 2013, 15:33 »
Apart from pollon filter what other parts will I need to the service
Offline mar_k
Re: Service kit
« Reply #7 on: 18 September 2013, 20:45 »
Depends what level of service your car needs,
Oil/Filter
Air Filter
Pollen Filter
Fuel Filter
Plugs
Coolant change (every 3-5 years depending on what coolant is used)
Brake Fluid Change (every 2 years)
Cam Belt Water Pump
Brake pads/discs
all of the above may need changing, I would say if the history of the car is unknown then I would be changing everything listed, except the brakes unless they need to be.
« Last Edit: 18 September 2013, 20:47 by mar_k »
Offline mcgee9t2
Re: Service kit
« Reply #8 on: 18 September 2013, 21:14 »
look in the maintenance section. theres a thread on servicing.
Offline dom
  • Back in a Mk4
Re: Service kit
« Reply #9 on: 18 September 2013, 21:34 »
