Author Topic: Cut out troubles  (Read 1705 times)
joeyGTI30
Cut out troubles
« on: 17 September 2013, 20:42 »
I have a 1997 GTI 2.0 16v and it keeps cutting out. It cuts out when I pull up to stop and have my foot on the clutch ready to stop or change gear. Anyone got any clues what could be the problem here? I'm thinking filters or plugs?
I also have the coolant light flashing constantly. The reservoir has been changed, the levels are fine, the sensors have been looked at and bypassed but the problem still persists. Any clues?
Offline itavaltalainen
Re: Cut out troubles
« Reply #1 on: 23 September 2013, 20:13 »
does it show temp correctly? if not then check coolant temp sensor, i posted a how to for this on this website, search will find it.
joeyGTI30
« Reply #2 on: 23 September 2013, 20:45 »
Yeah got the sensor on order. Still cutting out though.
« Reply #3 on: 23 September 2013, 22:36 »
did you measure the sensor before you placed an order?
any fault codes?
joeyGTI30
« Reply #4 on: 25 September 2013, 18:00 »
Sorted... It was the sensor but I still have cut out problems. I'm thinking it's to do with the air system... Induction kit may fix it!
