Author Topic: Airride suspension frame mods  (Read 2586 times)
Offline Mk1golfnoob
« on: 17 September 2013, 17:54 »
Looking at getting a mk5 gti and want to get it tuned by apr and put on airbags. Anyone know what frame mods you have to make apart from removing roll bar to fit the slam kit ? Might be same on mk4 or 6 ? Thanks
Offline dom
  • Back in a Mk4
Re: Airride suspension frame mods
« Reply #1 on: 17 September 2013, 18:33 »
You'll need a chassis notch at the front :wink:
Offline Mk1golfnoob
« Reply #2 on: 17 September 2013, 19:03 »
For the lower arm or ? And how much you gotta take out ?
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 17 September 2013, 23:11 »
Chassis notch is for driveshaft clearance. How much, depends on how low you want to go... wave goodbye to chassis integrity once notched!
Thom
Offline Mk1golfnoob
« Reply #4 on: 23 September 2013, 22:06 »
Thanks for the info and its going to have a slam kit so as low as it will go, and I'm not a badger ill strengthen it somehow rather than just cut it and leave it
Offline Thom89
« Reply #5 on: 23 September 2013, 23:02 »
I wasn't suggesting that you "just cut out and leave it"
Generally, a radius is cut out of the chassis leg, this gives you the clearance you want, then a piece of steel is formed to fit this radius, and welded into place... although this is very strong, you have still compromised the chassis legs, that could have implications on how the chassis would collapse in a frontal collision...
As long as you know this, then the decision is up to you :cool:
Thom
