Author Topic: help needed with ko3s pipe work from turbo asap  (Read 4791 times)
Offline darren1.8t
  • I HATE FRENCH CARS
« on: 16 September 2013, 07:07 »
right guys I fitted a new ko3s to my auq on sunday!! but were do I run the pipes correctly? on the tip there is a stump for a hose and im stuck witch way they go ? does any have a decent picture? I have 2 pipes from n75 then a pipe from actuator what goes were as I think I have done them wrong help would be great cheers guys
this is not my turbo but the pipe from the outlet tip were should that pipe run?
« Last Edit: 16 September 2013, 07:41 by darren1.8t »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: help needed with ko3s pipe work from turbo asap
« Reply #1 on: 16 September 2013, 10:46 »
I'll have a look in a bit but I'm sure that goes to your N75 as well
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 16 September 2013, 11:44 »
Ah hang on, doesn't that one go back to the carbon canister?
Offline rfn_hodgson
« Reply #3 on: 16 September 2013, 12:14 »
Wazzer you are right there. I only know this I've I've just done the ultimate delete and that does go to the carbon canister I'm sure of it!! :)
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 16 September 2013, 12:43 »
Yeah mines blocked off too
Offline darren1.8t
« Reply #5 on: 16 September 2013, 18:09 »
 has anyone got any pics  to were the pipes should go?
Offline darren1.8t
« Reply #6 on: 17 September 2013, 06:17 »
 :sad: anyone
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 18 September 2013, 12:33 »
No cos mine has gone... It runs under the scuttle back to the catch can though.
I can tell you where the pipes should go on the N75 if you want?
Offline dom
  • Back in a Mk4
« Reply #8 on: 18 September 2013, 13:05 »
It runs differently on an AUM so I'd guess it's the same on an AUQ as well. The pipe does not run along the scuttle to the carbon canister, instead it joins a hardline that runs along the right hand side on the block (near the combi valve for the SAI). This joins a second hardline that runs along the front of the engine underneath the FPR.
A hose comes off the second hardline and T's where the finger is pointing in the picture below. One end goes to the TB and the other to the carbon canister.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 18 September 2013, 15:09 »
Ah yes sorry it's all linked up with those hoses near the inlet...
